Sedan Chat Thread
#2912
#2914
#2915
If you look at the Tire Rack test I linked, they actually did some instrumented testing, same car, same track, same day...No real difference in wet/dry braking distance, no real difference in slalom times, no real difference in lap times. The only significant advantage the PSS had was skidpad, .98 to .91
It looks like C&D has taken down the actual results, but I don't recall lap times being significantly different.
When I got S04s the price difference was more than $300, last I looked, Michelin had a $70 visa card rebate.
Is the difference in performance worth it to you? For some people yes, others, no. I plan on getting the PSS next, so I can see if they live up to the hype.
The 050A is an older tire design.
#2916
Both tires are designed and positioned for the same market. However, your criteria for relevance must be pretty impressive, so whatever expertise you have here, I suppose I'll defer to it.
#2917
No. I haven't decided. Very much on the fence about it, and figure I need a break from modding the car for a couple months. Worse case is that I asses tire wear when the snows go back on. Remember, I don't drive nearly the kind if long miles that you do, so it seems a reasonable risk.
I found the camber kits for a darn good price so I think I'm going to suck it up and make it happen. I'll hold off on a tune though, NZ is definitely calling my name.
#2918
A quarter past stripped
Was at the dealership today and spoke to the man that sold me my sedan. The redesigned "G" coupe will have the Q50 front end and an added 2 inches of width on each side of the car starting behind the doors. "Think in terms of the camaro" it will have a flare in the rear with a wider wheel base. No pictures of it yet but the salesman did say that they (the sales people) had a meeting about two weeks ago on the new vehicles coming onto the playing field. He also confirmed that they will be offering a model of the Q60 with the GTR engine inside to go along with the Q50ER. Just thought that this info would be fun to mull over.
#2920
Somebody hit my damn car last night. It isn't bad, bad enough to **** me off but not bad enough to report anything or get the nose replaced. "Just" scuffs and scratches.... I can't wait to move.
But, on another note, just ordered springs and camber kits. Time for some adjustments again.
#2921
Sorry to hear this, Chris. Glad it wasn't worse.
Camber kit, too, eh? Both front and back? That wasn't cheap.
#2923
A 1/4 mile @ a time
Somebody hit my damn car last night. It isn't bad, bad enough to puss me off but not bad enough to report anything or get the nose replaced. "Just" scuffs and scratches.... I can't wait to move. But, on another note, just ordered springs and camber kits. Time for some adjustments again.
#2924
