What's next for Newt?
blnewt (03-27-2016)
#123
I did a full detail/polish this weekend so shiny and smooth.
Anyways,
Did you use knifeless tape? And 3M vinyl?
I actually tried to wrap it but i used some junk VIVID vinyl, which is nearly impossible to get bubbles or wrinkles out so i trashed it and ordered some 3M. Comes tomorrow..
Anyways,
#127
Anyways,
Anyways,
Thanks Tanner, and ditto on the work you've done recently
Here's a link to the tips, they're a clamp on since I wanted black. I may have a friend tack weld them in back to remove the bolts, we'll see. Don't really notice them much. And I like the look much better than the bright stainless silver tips
The new Y pipe did add a bit off hiss/rasp at 2800 to 3000 rpm but only under hard acceleration. If it stays as is I'm ok with it, if it get worse I may
look into modifying that 3" to 2.5" transition that we talked about.
http://carkart.com/index.php?route=p...uH8aAo7z8P8HAQ
#128
Those tips... very unique. The finish is an aggressive, subtle look that totally works with your car and all the black trim. Great choice, Brad.
How very Porsche of you.
blnewt (03-28-2016)
#130
Is this your Build Thread now?
#132
I just popped over from the coupe forum because I'm bored at work and was looking for some new threads to lurk through. Just wanted to say that Newt's help and influence has not gone unnoticed on the 2-door side as well. I know I have personally benefited from his advice (among many others who are staples here on the forum) and it's really refreshing to see someone who is consistently helpful and knowledgeable. I wasn't sure what to expect from this forum when I got my G because my buddy had a 350z and that community is absolutely toxic. I've had a great time here and learned a lot. So... go us?
The following 2 users liked this post by JUMBO PALACE:
blnewt (03-29-2016),
ColumbiaSkinny (03-30-2016)
#134
Just got some boxes from Japan today, huge shout out to Jason@GetYourWheels, he did a great job w/ the order and I've never had anything arrive in such immaculate condition
Wheels are Wedsport 18x9.5 +38 and weigh 20.4 lbs per wheel, these have plenty of room for Akebonos and even more for my Wilwoods
Should have them mounted before the weekend.
The following 3 users liked this post by blnewt:
