Undercarriage rust in 2010 from FL?
I am looking at two G37S sedans, both just off-lease from Florida. (I am in north Texas.)
One has about 30K miles and has a super clean undercarriage. The other has 40K miles and has rust spots all over the exhaust. Also, bolts and other exposed parts show surface rust. I didn't take a picture (argh), but the rust spots look like the early stages of a rotted out exhaust.
Inside, the rust-free 30K one has a funny odor that I can't put my hands on, but the 40K one with rust spots smells clean.
Other than the rust, both cars are clean. Both have clean Carfaxes.
Is it normal that a Florida G37 would show this kind of rust, or does that indicate a larger problem?
I don't think so! Some parts of Florida had very heavy rain and local flooding.
Means nothing. Not everything gets reported.
They are both 2010.
This is the one with 33.7K miles, asking $25.9K: 2010 Infiniti G37 Sedan Sport Garland, Texas | Certified Carland Llc. Underside was very clean. Problems include:
Carfax suggests both cars lived out their leases in Florida.
Correct. I see it as just an initial indication.
- Engine seemed to be a little rough on cold start.
- Lots of road noise at regular speeds (only got up to arond 50). Not sure if it's because of tires (Hankook Ventus V4 ES) or something else.
- Off smell in interior, but wasn't cigarette smoke or must.
That's what I wonder. I imagine the exhaust will be fine for a while to come but may need premature entire replacement. The difference between the undercarriages of the corroded one and a nearby one, both virtually identical G37S cars from Florida, were night and day.
If the car was driven and parked close to the beach, it wouldn't be unusual for it to have MILD surface rust on the undercarriage and exhaust. I lived in Ft Walton Beach for 6 years and parked my Corvette in an open carport. Every morning I could see the surface rust on the brake discs just from sitting overnight in the salt fog. Surface rust is common from the ever-present night fog rolling in from the Gulf or Atlantic (depending on which side of the state the car was on). If it was driven on the beach or on beachfront roads, the rust will be worse. It's also possible that the car was a flood victim. Check inside the cabin and trunk, especially under the carpets and trunk mats for any evidence of rust. If there is any, run, don't walk away. Also check to see if any of the interior parts, such as seats, carpets, door panels or audio systems, have been replaced with "fancier" after-market parts. It's not unusual for dealers to replace those damaged items on flood cars and then try to explain the new parts as "upgrades". Also, most folks assume that a car that's been flooded will have a tell-tale mildew smell. That's not necessarily so; I know two folks who unfortunately bought flood cars that had no odor at all until a couple of weeks after purchase. Bottom line: rust is never good and the buyer will usually end up paying for it later on. IMHO, the difference between a G37 with 30k miles vs. one with 40k miles is probably not a significant issue. A rusted undercarriage is.
Being from texas, he prob sees a little discoloration as a lot of rust. Bringing my above average cars to Miami and they always can tell it is a northeast car because the rust is much heavier. So the "rust" may not be a big deal. As others have said, water pools up fast on rainy days.
A few things to check:
As stated under the trunk pad.
The rear seat cushion pulls up by pulling a clip from under the seat. Pull that out anc check for previouse water logging, rust, smell.
Check the front seat brackets. There should be no rust in a car that young.
See if there is evidence of significant dirty wated behind the battery and brake master covers.
You can get creative by looking in spots that most places wouldnt clean up very well but the 10k miles is not a huge deal. Just figure out what options/colors you like best.
The car lived in Fort Lauderdale, FL apparently. Wouldn't surprise me if was near the Atlantic much of the time.
Prometheus
General Tech Questions
11-09-2015 01:23 PM
butwhatuptho
10-04-2015 07:51 PM
