shudder at stoplight
So i have and 09 sedan 49k. I had the new program on the tranny about 9 months ago but heres the problem, it seems every time i come to a stop after about 3 seconds i just feel a slight shudder. almost like the car wants to push an inch foward. It happens all the time. wondering if anyone has had this. i brought it to the dealer and they said they will reinstall the program but idk whats up. any suggestions would be great. thanks in advanced
I only experienced it one tune and when I press on the gas pedal it lurched forward. It was so rough the thought I broke something in the transmission. Thankfully never happen again.
Try ecu rest, can't hurt.
http://www.6mt.net/forum/performance...rocedures.html
Ive cleared the computer several times when i put on and off my k&n typhoon threw a code(vac leak) and it has still done it, now back to stock. Also it only happens when my foot is on the break not when im moving, usally when i come to a stop sign or light after driving around. Thanks
I have something similar - after I come to a complete stop with the engine at idle the car shudders a bit. It's hard to explain but it almost seems to be resonating causing rattling some somewhere inside the dash. If the idle goes up even a fraction (with me slightly touching the gas while still holding brake), the shuddering goes away. If I am at rest long enough, the shuddering goes down which I believe is due to a slighly lower idle. It is most noticible when the radio is off and actually reminds me of the idle in a dinky 4 cylinder. With the radio on, I don't even notice it.
The car is butter smooth (without rattles) everywhere else in the RPM range while in motion.
Brian
Brian
aliiin
04-27-2018 10:37 PM
ashmostro
11-08-2012 05:13 PM
