Noticed a sound difference when shutting door on a 2012+ Sedan
I have a 2009 Journey Sedan. Lately I have taken my vehicle into the dealership to get certain items replaced under warranty such as my steering wheel cover finisher due to the rubber peeling off. Each time I have gone to the dealer for warranty repair I have been given a loaner vehicle which happens to be a 2012 model. The first thing I noticed when getting into the car is that the sound of shutting the car door sounds different from my vehicle. The loaner vehicle sounds light whereas my car sounds heavy. I've noticed that when I close my doors they have some resistance and even if you slam the door they don't slam shut. On the new model when shutting the door I noticed no resistance and doors slam hard. I know Infiniti changed things in the newer models such as upgrading the sound system and adding usb. However, they deleted some things from the older models to save money such as the power lumbar support. I am wondering if they decided to cut back on costs in the door insulation and weatherstripping materials. I might be imagining things, but are there any other 2009 and older model owners that have experienced this?
![Confused2](https://www.myg37.com/forums/images/smilies/confused2.gif)
I haven't noticed this, per-say, but a problem that I have noticed when shutting my doors lately is that there is a vent in the rear quarter panel, when I shut my doors I hear that vent open and close. It sounds like shutting two doors at once, but they're a fraction of a second off so you still hear two individual doors close. I've talked to the dealership about it but they're response was that it was "normal". I have yet to notice it on any of the loaners that they have given me, both 2012 and 2013 and G37s and G25s. "Its normal" will not cut it with me. I will find a way to fix it... eventually.
Anyway, I wonder if this is what you're noticing, or if it is something different.
It could be the air in the cabin moving as closing the door builds up pressure. Infiniti must have changed something because I noticed a difference. Maybe it was building up too much pressure. This came to my attention when I had my windshield replaced with another oem glass. The installer cracked open the windows because he said the windshied could move out of position when shutting doors during the curing process. I think it is due to the build up in air pressure that I noticed more resistance when closing my doors vs. the newer model.
My 07x sounded the same as my 11S and requires the same effort to close. No noticeable difference for me.
Perhaps your door is not aligned properly or a slight problem with the hinge?
![Dunno](https://www.myg37.com/forums/images/smilies/dunno.gif)
I have a 2009 Journey Sedan. Lately I have taken my vehicle into the dealership to get certain items replaced under warranty such as my steering wheel cover finisher due to the rubber peeling off. Each time I have gone to the dealer for warranty repair I have been given a loaner vehicle which happens to be a 2012 model. The first thing I noticed when getting into the car is that the sound of shutting the car door sounds different from my vehicle. The loaner vehicle sounds light whereas my car sounds heavy. I've noticed that when I close my doors they have some resistance and even if you slam the door they don't slam shut. On the new model when shutting the door I noticed no resistance and doors slam hard. I know Infiniti changed things in the newer models such as upgrading the sound system and adding usb. However, they deleted some things from the older models to save money such as the power lumbar support. I am wondering if they decided to cut back on costs in the door insulation and weatherstripping materials. I might be imagining things, but are there any other 2009 and older model owners that have experienced this? ![Confused2](https://www.myg37.com/forums/images/smilies/confused2.gif)
The doors on my 2012 G37 do seem to close slightly better than those on my old 06 G35
Telcoman
Lt8Che
91
04-08-2022 04:55 PM
