Eeeeuuuuuuuuurrrrrt!
Very, very nice. I like that you got slots, but didn't go overboard with drilled rotors. What's the make/model? Links for parts?
I also like how the rotors lined up perfectly between the spokes on your Coupe rims. Coincidence, or do we have a compulsive-obsessive photographer here?
They are actually through slots!
www.racingbrake.com
And yes, i noticed the way the bolts lined up! Since there are ten disc mounting bolts and five lugs, they will always appear this way regardless of the way you mount your wheels (which are also ten spoke in this case)
www.racingbrake.com
Wait... $920/pair?! oh. my. god.
Brand listed above already, but here it is with a direct link to the product page: G37S (Akebono) - RacingBrake.com
Yes, I already have SS lines, but I disagree with your statement.
Pedal feel is a combination of actual stiffness, which can be slightly impacted by the hardness of the rotor, and much more so by the compressibility of the pads- and the the other impact is the perceived stiffness due to increased initial bite. Stronger initial bite means less pressure needed at the pedal which can trick the mind into thinking the pedal got stiffer. I think this is playing out strongly with this setup because of the slots and the way the harder iron is microwelding to the pads. This might go away after all the cross-hatching is gone (will take a while, again, because of the harder material).
