Can't Add Phone Numbers 2012 g37 Sedan
Old 11-06-2012, 07:03 PM
smokes
smokes's Avatar
2012 G37X Sport with premium package (sedan).
The system recognizes my phone, which I can use hands free, but not only will it not access the phone book from the phone, but I cannot manually add phone numbers to the phone book. I get to the phonebook (which has no names in it), but there is no tab to "Add New." I can only speak the numbers and then ask to dial, or access recently called or received numbers.
Tried searching the forums in vain, to no avail. Sorry if I missed this discussion elsewhere.
Old 11-06-2012, 07:15 PM
telcoman
telcoman's Avatar
Are you trying to add the phone number while parked?
Telcoman
Old 11-06-2012, 07:20 PM
smokes
smokes's Avatar
Telcoman
Yes, the car was running and in "park."
Old 11-07-2012, 12:50 PM
GeezerB
GeezerB's Avatar
Did you import your phonebook first?
Old 11-07-2012, 07:05 PM
smokes
smokes's Avatar
Originally Posted by GeezerB
Did you import your phone book first?
Tried, but it wouldn't work. The phone (LG Rumour...older bit of junk), says it will do this, but it did not work. The car recognizes the phone and I can use it to make calls if I speak the number. The manual states that I should be able to add numbers manually even if I cannot upload my phone book, but I never get the Add New icon in the phone book.
Old 11-07-2012, 07:10 PM
GeezerB
GeezerB's Avatar
Due to the age, that phone probably doesn't have the correct bluetooth profile built in.
Geez, phones are practically free these days. Time to update?
Old 11-08-2012, 01:44 PM
Marc Collins
Marc Collins's Avatar
Do you see two phonebooks--the one built-in to the car and the (empty, not working) one where your phone contacts should be? Make sure you are trying to put entries into the car phonebook.
Old 11-08-2012, 02:35 PM
kaoticdemize
kaoticdemize's Avatar
hit the phone button then go to handset phonebook, what happens? You may need to update your phone too.
ericmadGRR
04-26-2016 01:27 AM
BANNISTER
12-10-2015 04:14 PM
Raye D. Ater
11-09-2015 12:58 PM
pledes23
08-11-2015 10:54 AM
Madorable
08-08-2015 11:13 PM
Quick Reply: Can't Add Phone Numbers 2012 g37 Sedan
