bigģggggg problem need help asapppp
I have an 07 sedan ... with intelligent key. .... the car all of a sudden does not want to do anything .. the key fob does not lock or unlock the doors....the interior lights do not work at all the .....car will not start ... but what is weird the power seats still work....... the fob battery is brand new and so is the car battery itself ........im thinking the BCM might be bad or something with the CAN system.....i need help asap can anyone chime in?
Shot in the dark but easy....put the key fob in the key slot to the lower left of the steering column. If it starts then the fob battery is the issue.
If you are sure the car battery is good, disconnect the neg terminal for a few minutes and reconnect. Try again.
Did that a couple of times lol .... the car literally does nothing like theres no power going into the car
If you have not tried to disconnect the battery / reconnect after some time (hours?) - give that a try.
After that - isn't there a main breaker? Check them all...
If it all is unsuccessful - I'd take a volt-meter to the battery - and start tracing the power if at all possible.
WHich part did you do a couple of times? Put the fob in the slot? Or disconnect/reconnect the battery?
The fob doesnt work period doesnt unlock or lock doors... when i put in slot still does nothing.....the car is acting as if there is no main battery...... fob has brand new battery..and the main battery is brand new.....like i said the weird part is the power seats work.....and literally nothing else ...like the car locked me out ..... or is in some security mode..main breaker? Where is it located?
When you say the fob has a brand new battery - how new? Has it ever worked? have you checked the obvious? Like - is the fob battery in backwards?? Checked it with a simple battery tester? Have another fob to test it with?
PS - trying to remember....but I don't think the seats need the key to work
butwhatuptho
10-04-2015 08:51 PM
Msherburneg37xs
Intake and Exhaust
09-30-2015 07:39 PM
FlyIce
09-29-2015 05:07 AM
