Bird poop stain - What would be the solution?
Regarding the water spots.
I used a 1:1 mix of distilled water and distilled white vinegar to attempt to remove them from the glass today. Worked perfectly. It's important to buff out the area with a dry towel before the liquid solution has a chance to dry, otherwise spots may remain.
I then tried a section of the painted hood. Worked equally well. I won't do the whole car until I have a chance to wash it again. There's already a number of fine particles on the paint, so doing it right now will likely cause scratches. It's a bit cumbersome but I think the process will go something like this
1) wash car thoroughly and dry
2) use the vinegar/water solution to remove spots
3) repeat #1
4) wax/seal
3) repeat #1
4) wax/seal
Bird droppings are acidic and if left unattended long enough, will eat and etch into the clear coat. If this happens you may or may not be able to sand and buff it out. It all depends on how deep it penetrated. Before doing any kind of detail work, use a vinegar/water mix, baking soda/water mix, or some all-purpose cleaner (all alkaline mixtures) to neutralize the area. If it is not neutralized it will almost always return.
Hope this helps and good luck..
I just had a car wash on Sunday and Yesterday when I'm wiping off the bird poop spot I noticed there is yellow-alike stain underneath the clear coat, I tried to clay it but it wont come off. My question would be does it really penetrated through the clearcoat? Will there any remedy solution? Also will high temperature casued bird stain penetration faster process? (the day LA is about 105F and when I'm wiping the car it's not under cool surface condition)
Thanks!
Thanks!
cconklin2
01-09-2016 07:21 PM
delfinparis
10-08-2015 06:06 PM
butwhatuptho
10-04-2015 07:51 PM
KZK
Canada
09-23-2015 11:52 PM
