bad gas mileage 200 miles a tank
That sure doesn’t help. You’re getting 0 mpg during that time. Just warm until the RPMs drop toward 1k, about 30 seconds. This is when the computer knows the fuel mixture is good to go.
try reducing your "warmup" idle time and see if that helps, but i suspect you have other fuel issues as well if you're only getting 200mi. running rich?
also with 70% city driving and a heavier foot youre lucky to get above 16. ive got the 5AT and i do about the same driving and im hovering around 16.5
Senior Citizen
I would consider myself a conservative driver but for city driving I average no better than 15.5mpg, but for highway use it jumps to 25mpg. The best I ever did on a long trip was 27mpg.
Some interesting figures here, I get 15.2 mpg (90% NYC traffic) after an Uprev tune on the "economy map", a bit better than what I got when I was stock (14 mpg from what I remember).
#29
I was averaging about 17mpg through 80% city. If you have a heavy foot, and you idle the car for 4 minutes every morning (prob about how long it takes to get the gauge to the middle) averaging 16mpg is about accurate.
#30
Idling will eat mpg for breakfast. You never mentioned terrain or lengths of trips. If you idle for 2-4 minutes and then drive 15, it is easy to see the drop. I live in a hilly area and most of my trips are only 10-15 minutes from start to stop(including the few seconds to minute for the catalytic idle, most of the time).
I have found my local average is skewed towards the city rating on all my cars. When I have combined tanks that include trips to Houston, I can get right around highway rating.
I might have missed it, but how many gallons do you add at each fill? Running it to the fill light will produce 17-18 gallons of space. 0 miles on range is calibrated to abbot 18.
