How do I unlocks my locks?
In that so it doesn't automatically lock after you hit a certain speed. For some reason the driver side and rear doors will lock but the front passenger side doesn't and it's getting annoying when I leave the house and get in the car and realize I forget something and try and open the door and find it locked because the car's running.
I'm confused as what your car is doing.
So your front passenger door doesn't lock, when the other 3 do.
But sitting in the car with engine running causes the car to lock, instead of the speed sensitive setting?
Ok, I guess no one picked up my sarcasm. Anyway, to the op. If your doors are locking except the pass door, something is broke. If you don't want the doors to lock, you can turn it off in the comfort setting. Ie: same menu to turn on or off the seat and steering wheel from moving out of the way on shut down.
If I'm reading your problem wrong and the car just locks when you get in, take it in.
Sorry guys I worded it poorly. I meant to say when the car automatically locks when you hit 18MPH. My point is sometimes I get on the road, realize I forgot something and drive back to the house, and then want to run back into the house with the car running and slam myself into the inside of the door because I assume the car is still unlocked. For some reason the front passenger side remains unlocked while all other doors are lock. Other times I drop my kid off at my parents to take him to school when I have to go to work early and want to run in and tell them something quickly while the car's running and always end up shoulder checking my door.
Simply put, is there a way to program the doors NOT locking when I hit 18MPH. I assume there is because the passenger side is programmed not to unless that is some weird design. We really don't get car jackings in Toronto so I really don't think there is a benefit for the doors to automatically lock and in case of an accident, I would prefer that those doors remain unlocked just in case.
I'll try the menu again but it doesn;t seem to work and no the car doesn't unlock when in park except for the pass door I assume. I will check to see if the pass door is unlocked while in drive at a stoplight but I thought I read hear somewhere you have to press down on the lock buttons for a few seconds or something to that effect to program to not automatically lock.
My bad. I always get those confused. Page 3-5 of owners manual shows how to deactivate the auto lock at 15 mph. It does involve pressing the unlock button down for 5+ seconds with ignition on. Hazards will flash when complete. Also the doors unlock when ignition is placed in off position. Should be park position.
You can not control the door locking in motion feature from the comfort settings.
Here is what you do.
- press the car start button to the ON position ( do not start the car)
- hold down the driver's side door lock button until the hazards flash.
Repeat to enable/disable the auto lock in motion feature.
