Trunk not opening with key or button on trunk?
Old 03-08-2012, 09:45 AM
Infiniti7
Infiniti7's Avatar
So I started up my car this morning and after that I went to go open my trunk to get something out and I noticed when I had the key in my pocket and went to press the button on the trunk it would not pop open. So then I tired to hold down the button on the key and that did not work either. So finally I manually did it from inside the car and that work. I closed here trunk drive a mile or two and now the button and key both work again. My key is sort of low on battery but I don't think that's the reason why it wouldn't open my trunk. Anyone have any thoughts or ideas why this happened?
Old 03-08-2012, 10:02 AM
BLamb
BLamb's Avatar
maybe since the car was on?, would hope you couldn't open the trunk by pushing the button on the back, would mean anyone at a stop light could pop your trunk and grab your stuff while you're sitting at the light.
Old 03-08-2012, 10:11 AM
GET_SOME
GET_SOME's Avatar
^--- bingo car must be off to be used with the key or button. must be manually opened from inside
Old 03-08-2012, 10:16 AM
Infiniti7
Infiniti7's Avatar
O really? But the key was in my pocket so I figured it would open. When your sitting at a stop light the key is in the front seat with you
Old 03-08-2012, 10:19 AM
GET_SOME
GET_SOME's Avatar
does not matter
Old 03-08-2012, 10:22 AM
Infiniti7
Infiniti7's Avatar
I'm sort of confused because I feel like I have opened my trunk when car is on and key in my pocket. Today it didn't work. Are you sure you can't open trunk when car is on key in pocket and you press the trunk button on the back?
Old 03-08-2012, 10:34 AM
GET_SOME
GET_SOME's Avatar
it has never worked for me .
Old 03-08-2012, 10:36 AM
Infiniti7
Infiniti7's Avatar
So when car is running the only way to open trunk is manually doing it inside even if you get out and the key is in one hand and you press the button on the back to pop it. It still won't work? Car has to be off?
Old 03-08-2012, 10:59 AM
sniper27
sniper27's Avatar
That's what he said.
Old 03-08-2012, 11:03 AM
GET_SOME
GET_SOME's Avatar
lol i dont know any other way to explain it..
Old 03-08-2012, 12:35 PM
Infiniti7
Infiniti7's Avatar
I hear ya but I know for sure I have opened the trunk when the car is running by hitting the button on the trunk. That's all I'm saying
Old 03-08-2012, 12:57 PM
canucklehead
canucklehead's Avatar
who's on first?
Old 03-08-2012, 01:13 PM
ECain18
ECain18's Avatar
Well try it again lol. It has never worked for me. Also.. When the car is running, try using the remote to lock your doors. That also should not work.
Old 03-08-2012, 01:20 PM
Infiniti7
Infiniti7's Avatar
That definitely works for me. Sometimes I leave me car running when I run in the store real quick and I can lock the car for sure
Old 03-08-2012, 01:24 PM
Tazicon
Tazicon's Avatar
I have as well....................it might be in your setting that this can be changed. Oh and I can not open the trunk when the FOB is in the car (cupholder to be exact). It has to be right by the trunk.
Quick Reply: Trunk not opening with key or button on trunk?
