Trunk not opening with key or button on trunk?
Old 03-08-2012 | 02:45 PM
sniper27's Avatar
sniper27
Just read that your battery on your keyfob is low. That would cause intermittent issues.
Old 03-08-2012 | 03:15 PM
Infiniti7's Avatar
Infiniti7
yes my battery is definitely low on my key. i have not changed it since owning the car and i got in dec 2009. maybe the low battery had something to do with the problem I noticed this morning. if the key is on you (in your pocket) you should be able to open doors lock doors trunks ect
Old 03-09-2012 | 05:28 AM
maxfinity's Avatar
maxfinity
I can open my trunk via the button on the trunk lid with the car running. I do it all the time. Im not sure about the button on the keyfob though.
Old 03-09-2012 | 02:24 PM
Infiniti7's Avatar
Infiniti7
Same way here
Old 03-11-2012 | 12:40 PM
INFINITI G37's Avatar
INFINITI G37
Originally Posted by BLamb
maybe since the car was on?, would hope you couldn't open the trunk by pushing the button on the back, would mean anyone at a stop light could pop your trunk and grab your stuff while you're sitting at the light.
Hi
no one can pop the trunk up while the car is on unless he has the key with him and pushes the button within less than a meter range from the button..
Landshark
09-30-2015 12:20 AM
r0cketm0nkey
09-27-2015 02:34 PM
Allboutcali
09-26-2015 04:43 PM
