anyone's sedan cut off prematurely when pumping gas?
Old 02-29-2012, 12:46 AM
anorudo619
anorudo619's Avatar
fill limit vent valve inside tank is the issue if nozzle clicks off.
Old 02-29-2012, 02:27 PM
jojobucks
jojobucks's Avatar
TinsleyC is correct. I usually fill up at Costco and it happens sometimes-not all the time. I usually lift the nozzel up a little bit and it seems to work fine. I have found that if I pump at half speed it usually works fine. This is NOT a big problem, in fact it's kinda fun taking more time to fill the tank, that way I have a chance to look around at the other folks checking out my beautiful black G37--and watching them drool. He He.
___________________
2010 G37 sedan 7AT Black
Old 02-29-2012, 02:39 PM
DadsTaxi
DadsTaxi's Avatar
I always fill it up with the barely on setting on the pump (first click to just keep it pumping) never have an issue.
Old 03-02-2012, 10:08 AM
forrmark
forrmark's Avatar
I have only had that problem at a Hess station. It has shut off prematurely several times at the same Hess station, but no where else. Not what I would call a serious problem.
2011 smokey quartz g37/ premium/ nav/ 18" wheels
Old 03-07-2012, 11:08 AM
erick_G
erick_G's Avatar
go figuere mine always does this
Old 03-07-2012, 11:43 PM
parasailing
parasailing's Avatar
First time tonight it happen to me at a Costco station in my 2012 G37. It was near empty and I started the pump and 4 gallons into it, it would click. Tried several times to start it back up but no luck. So I started my car and drive to the filling station in front since they have two on each side and still happen so I just got back into my car and drove off.
I might try putting it upside down in one of the older threads that was posted to see if this fixes it next time or go with a slower fill.
Old 04-15-2012, 07:31 PM
dimsler
dimsler's Avatar
Whenever it happens to me, I just fill the tank with half the nozzle inserted, seems to work every time.
Old 04-15-2012, 07:51 PM
wetboy44
wetboy44's Avatar
Originally Posted by MalbecG37S
I had this situation on my 350 - if I remember correctly, the dealer ended up replacing a valve that resides between the tank and the fill tube.
On my daughter's Mazda3 - bad charcoal canister.
If none of the other suggestions work, bring it to the dealer and complain. I BELIEVE it is an emissions component (which maybe/might/possibly have a longer warranty than other non-emissions components)
Good Luck!
Yup, same thing happened to me, and the dealer had to order that part to repair it.
SBG37
05-05-2022 10:35 AM
Skyaddict
13
11-08-2018 07:14 PM
lobuzz311
16
10-17-2016 08:59 PM
Oh My G 523
04-01-2016 10:17 AM
SLEV3N
General Tech Questions
10-17-2015 05:58 PM
Quick Reply: anyone's sedan cut off prematurely when pumping gas?
