MY07 to MY10+ front end conversion question
Old 06-19-2012 | 12:09 PM
rpm&my_G35's Avatar
rpm&my_G35
Originally Posted by CFitz
According to Infiniti USA and many parts distributors, the headlights do not work with the old wiring harness. Apparently, I will need a new wiring harness to complete the conversion at a $1500 expense and even then my dealer will not do the conversion because they have never done one before and they consider it a liability. Is any of this true...?
Read post #3 above.
You shouldn't need to change the harness.
Old 06-19-2012 | 12:30 PM
ijahman's Avatar
ijahman
Dude find a good body shop to do te conversion no one I know of tat has done te conversion has used te new harness...I have my headlights and fogs wired from the 09 harness...most dealers are idiots
Old 06-19-2012 | 12:55 PM
imminence's Avatar
imminence
The original wiring harness will work, however, the shop performing the conversion will need to extend the fog light wires down to the bottom of the bumper.
Old 10-17-2012 | 02:36 PM
JCatch's Avatar
JCatch
Originally Posted by imminence
I've searched and feel pretty good about the list of parts needed for the conversion.
What parts are needed? I'm thinking about doing the same with my 2009 non-sport but I'm not quite sure what I'd be getting into, time and $$ wise.
Old 08-24-2013 | 01:37 PM
OMG_37x's Avatar
OMG_37x
i have a 2013 g37x sedan. what exactly do i need to convert the front bumper to a sport? And do the sport bumpers come with the LED daytime running lights?
Old 07-20-2014 | 11:04 PM
Leadwolf's Avatar
Leadwolf
Anyone recommends a body's hop in miami area? I want to do this mod, but would like a reputable bodyshop. Thank you
Old 09-15-2014 | 01:16 PM
montymofya's Avatar
montymofya
what bulb does the fog light takes i want to put some led bulb in there any suggestions or comments or recommendation?
Old 01-04-2016 | 02:16 AM
dbl07's Avatar
dbl07
Originally Posted by County-of-Kings
yeah i did the conversion, with the part list that ijahman gave me and it came out great
i just put hid's in the fogs tho, 6000k
AND I AGREE, BLUE SLATE'S G IS PRETTY BEASTY
AND IJAHMAN IF U SELLING LIP, LET ME KNOW
It looks great. I was thinking about doing the same retrofit. Was everything plug and play once you purchased all of the parts on the list? In other words, did you have to modify anything to get the parts to fit?
Old 01-04-2016 | 12:53 PM
Bocian's Avatar
Bocian
Nice job OP! Welcome to the conversion club
I did the 09 to 10+ swap. The harness bs that the dealer is giving you is just that, bs. The dealer is looking at the 10+ plug and your 09 harness and sees that the number of pins don't match since the 09 headlights have the fog lights built in. What I did was take the harness from the 09 lights and used that with my 10+ lights. The 09 headlights have an extra plug for those foglights embedded within, everything else is the same. I put hid lights in my fogs and just used the fog light plug from the 09 headlights harness and cut and extended it to my new fogs. That way you used the same harness throughout and you're basically just extending one plug. Also this allows for the factory fog switch to work just as it did.
As far as parts, take a look here
https://www.myg37.com/forums/build-t...onversion.html
This post has a very good write up, I used my old bumper reinforcement, just shaved off a bit so it wouldn't show through the bottom grille.
And look for used parts, it's worth the time
Old 01-04-2016 | 10:27 PM
flipmode007's Avatar
flipmode007
Looking for used part is a pain specially when you have search all over the U.S and Canada but when you get a good deal you will feel happy.
I just bought a 2010-2013 headlight for the left side for only $100 with bulb now I have to look for the right one with a similar deal, crossing my fingers.
Troop12
05-09-2018 03:40 PM
m3clubracer
09-11-2016 10:01 PM
Thedbarz
33
02-09-2016 01:05 AM
ddayeg37s
08-09-2015 08:10 PM
Quick Reply: MY07 to MY10+ front end conversion question
