How To Fix Minor Surface Scrape on Bumper?
so i was driving on the highway this weekend and i must of hit something on the road and i noticed that i have a minor minor surface scratch on the front right bumper. its not deep or anything. its almost looks like you can rub it off. any recommendations on how to fix it?
Your not covering it, you are rubbing it out.
I would use a new car paint rubbing compound. It is not as abrasive as ordinary rubbing compound.
Dampen a cloth and put a minimum amount of compound on it and start off by gently rubbing it over the damaged area. Then clean that area up to see if you have made any improvement. If it looks like it helped, repeat.
The key is to take your time and keep checking your progress.
You have to be careful not to rub too hard and/or too much or you may damage and/or remove the good paint.
depends on how deep the scratches are. You should post some pictures here. i can help you with that but only if u have pictures. Are the scratches on clear coat? Do they look like swirl marks? if its anything past the paint, you'll need a new paint job. If its only clear coat minor scratch/swirls use meguiar's mirror glaze 205 ultra finishing polish.
so i went to take a picture of my surface scratch and the scratch is so light and only seen really close that when i took the picture all i could see is a reflection of my in the car taking the pic. the scratch wouldnt even come out in the pic its so light. should i just not even worry about it?
ScratchX works great. You put it on and rub...really hard. I've gotten rid of some minor scratches. If you go deep into the clear coat you won't be able to get them out without a buffer.
mmnjtwa
09-07-2015 02:27 PM
