Show off your Sedans!
Stuff called “solution finish” got the plastic trim back to a nice, deep black. And it has lasted. I believe SF is technically a dye.
The lower grill on my front bumper became pretty faded (was parked outdoors for about 5 years, with the front end getting daily sun exposure).
Mequiars, on the other hand.
As for hard water spots, the trick to it is you need to fully dry the surface with a proper towel (if this is from washing on your own, sprinklers and other sources is another story), that way no deposits get left behind. Of course, easier said then done. The fix for removing hard water spots is using a acidic gel, 3D it's called eraser gel and Chemical Guys makes a similar product. Though that type of product you really, I mean really have to be careful with. You have only a short work envelope (I think 1 minute) to apply the gel and then you need to neutralize it with product such as 3D water-less wash and fully clean the surface. It will etch glass and cause damage if left on for a longer.
Of course, the alternative to washing with hard water is to use a product such as a foaming waterless wash was, 3D makes this too as well as other companies. I can try Eraser Gel the next time I am there as I would want to show her how to use the product: https://www.chemicalguys.com/product...r-spot-remover
As for trim "restorers" I believe most will just wash off or not last a meaningful amount of time and you simply just live with it. I could be wrong, but this is what I know from what I have seen.
Thanks for the tip on the water spots as my daughter lives in an area where it will rain hard, then the sun pops out and dries everything up in an hour. Her car is really spotted now. I had her try Magic Eraser as that sometimes works. No cigar.
It is satisfying to see her want to take care of the car and keeping it looking as new as when she lived at home. Wish my son would do the same.
Thread reminded me the car is overdue for a wash. Weekend activity if the weather holds up
Adam’s tire shine is now my favorite tire dressing. I’ve lost count of how many others I’ve tried.
The chrome wheels are even more particular than the painted ones. The chrome shop recommended using nitrogen in the tires vs air as it significantly reduces corrosion to the chrome on the inside of the wheel.
@Rochester Wheel shield is a ceramic/silicon coating of sorts?
socketz67 (Yesterday)
Rottten Appples
07-29-2009 04:15 AM
