anyone drive their g with VDC off?
#31
vdc @ slow speeds - can get you in a sticky situation when your expecting/needing power. it can also throw you off on turns, you turn with decent power expecting neutral/ a tad oversteer, instead power cuts and suddenly ur pushing like a bulldozer.
vdc @ high speeds - can save you bunz when your pushing it on some back roads or a nice on/off ramp.
i drive with it off, unless im driving all highway. maybe im just used to rwd with out it.
#32
The x is different. At any rate when the roads are wet I don't tempt fate. While the VDC won't save your hide when youre driving like a jerk, it's a safety measure. I've never had the issue step on the gas in a turn and have the power cut. However i usually don't have the need to floor it.
In my 350Z it was so easy to break the tires loose and the VDC would then cut power.
Funny thing is, my G37X Sedan seems quicker than the 350Z too. Of course it doesn't handle quite the same in the turns though...
#34
![](/images/premier.gif)
Second instinct to shut off VDC as soon as I get in the car...exceptions are snow on the road, heavy rain, and sometimes highway driving...
also, personally, I think that with VDC ON it eats away at the brake pads faster, just my opinion though...
also for the 'X' I feel like having the VDC off allows for the AWD system to be used/activated more effectively instead of just braking a slipping wheel, power is averted to where it needs to be.
Not sure about others but I'd rather go faster than slower...
#35
Love mine KPT module!
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
#36
#37
That's ridiculous. Pulling out in front of traffic is what's downright dangerous, not driving with VDC turned on.
#38
2007 G35 sedan figure 8s - YouTube
In the case of the X it's a different story. My X could never break free, on dry pavement, long enough to find out.
#40
I would say that in the case of the 2nd Gen RWD G35/37, VDC off means no nannies.
People were always saying when turning off the VDC there was still some traction control taking place on the Z. I don't think so...I could do to my Z exactly what was done in that video of the G.
I agree about the X...it wont really break traction because of it's AWD system. Sure does make for quicker launches than the Z ever did.
#41
I have been driving my G37x with VDC off since i read this thread a week back. I agree with others that its difficult for the G37x to break traction even after VDC is turned off. The car does feel slightly quicker to launch off of a stand still on dry and moist (not really wet) pavement.
I would probably be keeping the VDC ON in rain and/or snow and/or if the temperatures are below freezing (below freezing usually equals drastic drop in all-season tire grip)
#42
This. Why tempt fate if you don't have to. If you are at the track a whole different story. But on the street?
#44
With VDC off, all forms of traction control under applied throttle (including power management) are shut down however, all "BRAKING" enhanced systems (4 corner ABS) are still active.
