Stillen Front License Plate Bracket
I finally got a ticket for no front license plate. Rather than drill holes in the bumper and use the factory bracket, I got this Stillen bracket STILLEN : STILLEN '07-'08 Sentra and '08 G37 Coupe License Plate Brackets
I installed it on my '09 G37 Journey, and I'm seems to stick out more than it should. There is 1.5" clearance on driver side and 3" clearance on passenger side. Does that jibe with what other Stiller owners have seen?
never used the Stillen, but I prefer this. although you do drill holes, but at least it is on the underside so you can't see it. but the lower profile and being in the center is more appealing to me.
Skene Design License Plate Mount
SoCal Driven
As for the Stillen, i hate that thing. I have one, bought it for the same ticket reason, and when i screw it in it always sits a little crooked.
yea that sticks out way too much. i was trying to see if you bought the right one but it should be the same one as the g37 coupe according to the stillen site. your car is an 09 and it should be the same. the length of the bar is shorter for 2007-2008 g35 sedans though, not sure if that one would fit better
I have the STILLEN bracket for my 08 sedan. There are 2 different part numbers which I don't recall ATM. But I am pretty sure you purchased the wrong one. Mine has a tiny gap but nothing like that ginormous one. Call up Stillen, they might exchange it for you if you have the receipt. They replaced my hardware for free when I purchased a used one.
Application
2009 - 2011 G37 4DR
Description
w/24mm Tow Hook Thread Diameter - 7 1/4" Length (Stock Fascia)
Will Not Fit Nismo Edition
Part #
105465
The box it was shipped in says 105465 on the outside.
