Annoying center console trim piece creaking noise
Old 10-15-2011 | 02:59 AM
Rickyay's Avatar
Rickyay
anyone else notice a creaking, squeaking noise coming from the center console? like there is not enough lubricant to smooth and deafen the sound out. it is so freaking annoying, especially when i make turns in the corners. Anyone know how to fix this?
Old 10-15-2011 | 07:42 AM
soundmike's Avatar
soundmike
If it's anything like mine, the culprit would be the seat belt hinges. I sprayed some WD40 on them and the creak/squeak is gone. Give it a shot and see if it helps.
Old 10-15-2011 | 08:25 AM
If its the center console lid itself, the area making the noise may be the hinge. There's 4 screws holding it on. I used a tiny bit of lithium greas on the threads of each screw. I also sprayed a little silicone lubricant onto the hinge and onto the top and bottom of the flat part of the lid that attaches to the main body of the console.
Old 10-15-2011 | 11:24 AM
simonsez's Avatar
simonsez
I have the same creaking noise everytime i turn! Its a brand new car n pretty annoying/embrassing. I cant really spot exact location of it...
Old 10-15-2011 | 07:21 PM
Rickyay's Avatar
Rickyay
ok tnx for the reply everyone. Only thing left to do now is find a DIY on how to remove the center console pieces so i can spray that lube on....anyone care to direct me to that DIY if theres any? i can only fine the one for the old g35 sedan.
Old 10-15-2011 | 07:41 PM
tejasg37x's Avatar
tejasg37x
Mine only creaks when I put my arm on the console lid. It seems to be coming from the area where the two little pads are on the plastic that the console lid rests on. It's not very solid...it gives some and the plastic creaks.
Old 10-16-2011 | 08:27 PM
rpm&my_G35's Avatar
rpm&my_G35
I'm not sure what area of the console this creaking is from.
Is this an AT or MT console?
When I had my 07 AT sometimes the seat rubbed against the side of the console making an annoying squeek/creak.
My Sport seats don't touch the console so no problem.
Old 10-16-2011 | 08:58 PM
sniper27's Avatar
sniper27
i don't have a creak, but a rattle in the center console. It comes on sometimes when driving over rough roads. If i bang on it with my hand, it goes away. sounds like a screw or clip loose inside.
Old 10-17-2011 | 01:16 AM
Comatose's Avatar
Comatose
my 08 6MT's center console faceplates creaked like hell! just pushing against them with your finger would cause them to creak everywhere.
The 07 5AT I drive now doesn't have the same problem oddly. I think perhaps you need more of the velvet tape behind it to cushion it...
Old 10-17-2011 | 01:27 AM
Rickyay's Avatar
Rickyay
mine is an automatic trans, and no, my seats dont touch/rub against the side of the shift console area.
Old 10-17-2011 | 10:58 PM
KellySA's Avatar
KellySA
I have this sound that has been coming from what I think is the passenger seat, but now I am thinking the seat beat or console. It is extremely loud and kind of sounds like two styrofoam cups rubbing together. Is the the same sound everyone was having?
awightguy (03-18-2014)
Old 10-17-2011 | 11:50 PM
cy7878's Avatar
cy7878
I have a creak from the headliner from the back. it's annoying when the car goes over uneven surface.
Old 10-18-2011 | 12:23 AM
That's a pretty good description of the sound I hear too. Mine is very subtle, but the sound of a couple styrofoam cups is pretty spot on. I don't notice it as much once the car is warmed up and the temp inside the car is warmer. It is annoying though.
Old 10-18-2011 | 12:25 AM
Legz's Avatar
Legz
My 09 x coupe does that too, gonna bring it to the dealer soon...
Old 10-18-2011 | 08:36 AM
Pittjrs's Avatar
Pittjrs
This is an easy fix - my car was making the same noises whenever I rested my arm on the arm rest. Go to Home Depot and pick up a sheet of little rubber door stoppers that you stick on kitchen cabinet doors so the doors don't make noise when closed.
Open the center console, take two of the little circle door stoppers and put one on each area where the console door touches the center console when closed. These stoppers prevent the door from pressing down on the hinge (which is what is causing the creak noise), and you will be completely noise free.
Good luck
Quick Reply: Annoying center console trim piece creaking noise
