Question for ppl who installed the OEM front lip
I understand the OEM front lip comes with double sided tape. My question is if it's possible to put on the lip without using the double sided tape? The reason I ask is because I might need to take the front lip off from time to time, so I can put on the OEM front nose mask (for long road trips). The nose mask will not fit if there's a front lip.
Umm yes you can install it without using the tape, but then you will have to drill holes into your bumper and screw the lip to your bumper..... You better of using the tape....
