Are you running the subs from the factory head unit? If so how do you adjust the bass? Did you leave the factory mids/highs or did you change some speakers or the bose amp? Sorry for all the questions. Just contemplating getting after market subs but not sure about how it will integrate into the factory set up.
Pretty sure you can just get an inline converter and run the stock rca lines into the amp and then the subs. I did it on my old car, it worked out w/o a problem! Back when I rocked a RF 851S and 2 Power HX2s
yes i am running the subs from the factory head unit and left the factory speakers i changed out the amp to the one shown in the picture and i adjust the bass with an output converter which allows simple integration to OEM stuff. its pretty sweet you just install another **** and you can adjust it. i put the **** right next to the VDC and trunk button so i can easily adjust it.
Hey, I like the ride. I wanted to see if you have spacers on there or not? I'm looking at going with Vossens 19x8.5 all around with +32 offset and wanted to see how close to flush they would be with eibach drop and no spacers. Thanks
Thanks! and to answer your question no spacers at all. i just played around with the height of the ride and got most of the specs back in factory standards with the camber kit.
