G37 sedan Drag Race!
#31
sedans are very quick cars, quicker then coups actually (atleast in a straight line) All in the driver though. I have beat many cars that I should not have. Should be an attestment to the winning driver
Haven't heard of this company you were running with, i'll have to check them out, much cheaper then HOD.
If u live in CA and interested in attending next event i can send u PM with the guys cell that does the event.
#33
Ill tell u the way i drove and beat them.
1. Vdc OFF
2. Put it on DS mode.
3. Standstill gas+brake hold rpm on 2K
4. On go let off the brake floor the gas pedal
5. After passing 60mph the car should upshift to 3rd gear than downshift so it will go to manual mode so ull have the 3rd gear all the way to max redline.
1. Vdc OFF
#36
I agree. I owned an e46 M3 and it was much faster than my G37. It was a sad day to have seen it go, but winters in Chicago are no good for the e46. This must have been an inexperienced driver.
#37
1. Vdc OFF
1. Vdc OFF
#42
PS how much quicker are the 135's compared to the 335's? 135's are just as equally heavy, aren't they?
#43
#44
If you are looking at straight curb weights, yes around 30 lbs different with the G being heavier. I would imagine a new 335i with the 8 speed tranny would have an advantage due to the lower RPM that they have peak torque. At least for initial acceleration, not sure once you are talking a quarter mile run.
what's the difference between gross and curb? doesn't gross mean the very weight of the car AS IS, off the showroom floor? ie with all the fluids, seats, etc. in it? the curb weight is...just shell no? if so, why do we even consider looking at the curb weight...?
