It works!!
Old 03-31-2011, 06:00 PM
roots4x
roots4x's Avatar
Looks good man! I heard the X has especially soft springs. Does this help the ride out a lot? How does it compare to a RWD Sport (if you've driven one).
Old 03-31-2011, 08:03 PM
tristan1334
tristan1334's Avatar
That was the same spring I used. And I'm happy with it.
Old 03-31-2011, 10:42 PM
awais
awais's Avatar
How do you find the ride. Does it get bouncy on bumps?
Old 03-31-2011, 10:49 PM
tristan1334
Going over bumps are not bad at all. The one I hate are the dips, some of them feels like it's bottoming out.
Old 03-31-2011, 10:59 PM
D_Nyholm
D_Nyholm's Avatar
Looks good, just too much of a drop for me. Wish i could find something with about half the drop. Also looks like the rear is a little lower than the front...
Old 03-31-2011, 11:11 PM
eksigned
eksigned's Avatar
^ really?i wonder you'll think about the drop via the h&r springs d_nyholm. the eibachs give a very, very subtle drop. i like it!
STOOF
STOOF's Avatar
umm any springs made for the RWD 350z, 370z, g35 coupe, g35 sedan, g37 coupe and g37 sedan will all fit the X models. It just drops it a little more cause the X is higher.
Old 03-31-2011, 11:12 PM
eksigned
eksigned's Avatar
by the way, have you looked into some rear spacers? a small bit would help bring those out. then again...you're an X so you might have to do it all around...but don't take my word on that. what's your rear camber at? you planning on doing a camber kit? you could probably do without as long as your toe's in...
Old 03-31-2011, 11:14 PM
tristan1334
I have 15mm all around. And SPC camber front and rear.
Old 04-01-2011, 12:04 AM
Morrissey
Morrissey's Avatar
Can you elaborate on that? Rub?
Old 04-01-2011, 12:14 AM
D_Nyholm
D_Nyholm's Avatar
I don't want to have to get camber arms and I think that the tire being centered all the way around the wheelwell looks the best (to me), so that would only be about a .75" drop all around on an X. I don't think there is anything out there that would do that. THe S-Techs would be nice...if they made some for a X sedan!
Old 04-01-2011, 07:27 AM
cdso
cdso's Avatar
I ordered the same set. A good compromise between the non-x springs and stock. I didn't order any camber arms, hoping that an alignment will get it close to stock specs.
Old 04-01-2011, 08:33 AM
4drScreamer
4drScreamer's Avatar
G37X drivers will be happy riding low! Thanks for sharing!
Old 04-01-2011, 09:57 AM
  #29
NatesGr8
NatesGr8's Avatar
Looks good!!! I've had ProKits on my past 2 cars (00 honda prelude, 05 legacy GT) and loved them. Performance was great and they maintained almost stock like ride quality for both cars.
Old 04-01-2011, 11:02 AM
  #30
SindhiStyle
SindhiStyle's Avatar
what kind of numbers are you getting with your camber after the drop? I have been thinking about buying these for my X, but dont want to deal with camber arms as well...
Quick Reply: It works!!
