any one have this problem with the outside button on the door handle? i went to the dealer twice, first they replaced key fobs and reprogrammed them.. and then today they changed the driver side door handle and button.. the response of the button is intermittent, sometimes when the button is push it locks/unlocks right away, other times it takes like 7 pushes to get the doors unlocked.. the key is always in my coat pocket.. and my button was working perfect before it just all of a sudden it started acting up..
Hey Spingjp - not to high jack your thread, but I finally made a deal with Infiniti of Bedford. My car was shipped up from the south and was probabley there when you went yesterday. I pick it up tomorrow! Maybe I'll see you around
Could be an issue with the antenna inside the door or the actual button.
they replaced the entire door handle and button.. so i think it would of been fixed.. its just not responsive like how it was the first day.. it works on and off.. i have to hit it like several times to get it work sometimes and sometimes it works right away.. maybe i should unplug my battery and reset everything?
