Suggested improvement for smartkey
There is a product by Auto Enginuity that allows you to set things kind of like a Consult III (it also acts as a data logger/scanner).
You need to buy the base product and the enhanced Nissan/Infiniti add-on, I want to say it would be about 350 or so....far less than a Consult III but not the cheapest either.
This.
The service manual shows settings that can be made with the Consult III tool, one of which is to set how the trunk opens. (Im thinking Nissan should just supply every Nissan/Infiniti forum with a loaner Consult III so we can fix things like this
My salesman told me by default for 2011 they made it press and hold, where it wasnt like that before....said they were getting too many complaints about the trunk opening by accident.
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
Both my 2007 coupe and 2011 sedan are press and hold. I've had a few altima rentals an I'm pretty sure those are also press an hold.
They need to incorporate a hinged cover or shield for these remotes. Just a quick flick of a button on the side and it pops open. If you accidentally press the side button while it's in your pocket, it likely won't have room to flip open. Even a slide cover would be useful.
Wow, crazy. I've been using an intelligent key for the last 3 years (not specifically an Infiniti) and have never accidentally hit a button. Then again, I carry my key in one pocket, my phone in the other, and my wallet in the back. There's nothing else in my pocket with the key, except other keys. I also don't borrow my girlfriend's pants, lol.
As long as turning the remote off did not affect the push buttons on the doors and starting I would be fine with that ides. The only time I ever use the buttons is when it is by accident.
I liked an idea someone on one of the forums had....tear apart a keyfob and put the RF chip into your shoe (not sure about how to stash the battery). Then you dont need the fob and can start the car as long as you have your shoes on.
After having the car for about 6 months, I came out of a resturant with the wife to find the windows half down and it was raining. Ouch!. There was no permanent damage, just wet seats, but if I could disable that feature, I would.
I have for kicks used the FOB to lower the windows, but it is really a useless feature as you have to be so close to the car that it really does not have time to cool the car anyway before you get in.
I also occasionally get the alarm to going off in my garage. It is usually when I am bending over tying my shoes. This is not a big deal, but maybe I will try the suggestion to put the key somewhere else beside my front pocket.
BTW, this thread reminded me of this
YouTube - Miller Lite Skinny Jeans HIGH QUALITY VERSION
an on/off switch would be silly. recessed buttons would make more sense
you can do a number of other things to avoid your issues. I would suggest putting it in a jacket pocket, or getting a case for it
#29
I hate the "trunk open" feature. If I need to get into the trunk, I will press the button. I have found mine "open" on several occasions - concerns me due to a sub and an amp in the trunk. I will mess with some of the adjustments referenced on this thread -- thanks.
I have never intentionally used the windows feature and if I keep the car another ten years I never will. They did open unintentionally on one occasion so I will try to fix that, too.
misc
29
05-24-2023 03:57 PM
joebrez
09-22-2015 11:54 AM
