Yes, my 2011 also has a squeaking door look. The sound is coming from the rear passenger side. Very intermittent. Has anyone heard from the dealer service? Thanks!
Have you listened carefully and can you locate the sound?
Check to see if it is near your gas tank.
I had a similar issue where you would hear a squeak and what the dealer and I found out was that the locking mechanism for the gas tank was squeaking when I was locking and unlocking our door. I forgot what the part is called but the motor that locks your gas tank is probably causing the issue. My dealer had a similar issue with a different 2011. Both of our cars had the part replaced and now I don't hear the sound anymore.
+1 i have it too, I believe its not the passenger door but the the lock for the gas tank door...
Get it replaced at the dealership. Shouldn't get any hassle from the dealership.
Hids (front and reverse lights), swapped every single filament bulb for leds, intake, exhaust, cats, springs, and I'm over miles, dealer may not be to happy to see me =\
Aside from the gas tank door my, parking sensors are acting up, my font passenger window makes noises when I close it and I have noises coming from passenger door (possibly speaker)..smh
