Rear door wind noise
Old 11-30-2010 | 11:43 PM
financeman's Avatar
financeman
I purchased "Flowable Silicone Windshield and Glass Sealer" by Permatex from a local auto parts store.
Old 12-01-2010 | 11:41 AM
woodG37's Avatar
woodG37
Thanks financeman!
Old 12-01-2010 | 12:22 PM
cvroom's Avatar
cvroom
this is the same stuff i used too.
Old 12-01-2010 | 04:53 PM
brianashley's Avatar
brianashley
Hey all, quick update: Financeman knew the spot (rear most corner of fixed window). I could even see a gap in the seal from the outside. Car is at dealer now and they have overnighted a new rear fixed window seal for both doors. It seems there is a service bulletin concerning the wind noise issue. THey gave me a loaner G while it is being repaired...let's hope that does the trick.
BIG Thanks to everyone for the input and advice!
Old 12-01-2010 | 06:15 PM
Yosh's Avatar
Yosh
Same here....car went in for service yesterday. They called later saying they were ordering the seal/weatherstrip.
Old 12-01-2010 | 09:58 PM
financeman's Avatar
financeman
Please report back to us with your satisfaction with the repairs.....
Old 12-02-2010 | 10:47 AM
Yosh's Avatar
Yosh
Just an update.....
Picked up my car last night. They replaced the weatherstrip/seal and the noise is gone.
Old 12-02-2010 | 11:37 AM
jarena2104's Avatar
jarena2104
there is a tsb for that problem, i went in for mine but because i got body work they said they couldnt warranty it!!! lmfao
Old 12-02-2010 | 11:54 AM
cvroom's Avatar
cvroom
glad we found fixes for this problem. i have seen this problem come up on the forum before but a fix for it never came up.
Old 12-02-2010 | 11:57 AM
soundmike's Avatar
soundmike
financeman, thanks for the tip and photos. I knew of the TSB and even have a generic weatherstrip on hand to perform the fix myself, but i dislike having to disassemble so much just fix something so little.
So, last night, after seeing your idea for fixing it, i went and did it. It wasn't as messy as you made it sound, and took no more than a minute to perform. (Took me longer to find my cutter to cut open the applicator tub ). Definitely a quick and economical alternative to bringing it in for warranty work.
Fast forward to this morning, freeway, voila! No more hissing/whistling noise! Thank you.
Old 12-02-2010 | 02:02 PM
woodG37's Avatar
woodG37
Is the TSB applicable to 2010G? Anyone has description of the TSB? Thanks.
financeman - thanks again. On my way home today, I put a tape around the area you mentioned and amazingly, noise was gone for my 40 minute highway driving. Now I am in dilemma whether I should leave the tape on or make an appointment with dealer again.
Old 12-03-2010 | 11:33 AM
brianashley
Update on original post: New seal was ordered and installed for both rear doors...problem solved. Only issue was that dealer lost the key I gave them to the car. So I had to drive back home to get my second key....they reprogrammed me a new set. They realized I wasn't happy about their error.
Again, thanks to all for the help. This is why these forums are so valuable.
Old 12-03-2010 | 01:05 PM
movinon's Avatar
movinon
I would look under and between the seats for the key that they lost.
Old 12-03-2010 | 02:05 PM
  #29
ATL-G37s's Avatar
ATL-G37s
I have been having the same wind noise as described in this thread. I went to the dealership a month ago and they were not aware of any TSBs or reported problems. Does anyone have any information or documentation regarding the TSB?
Those that have had repair work done at the dealership, do you have any documentation describing what was done? This will be very helpful for those of us that would like to have this warranty work done.
thanks
Old 12-03-2010 | 04:16 PM
  #30
soundmike's Avatar
soundmike
It's ITB07-004.
