Is this normal?
Is this normal?
My brand new 2011 G37 is making a rattling (or vibrating) sound when I'm playing music. Or rather whenever something caused a shake... Even with just enough bass, it would frequently make that rattling sound from the glove compartment and/or right front door area. I first thought it might be speakers, but they seem fine.
Is this common? I mean if it was a modified speakers with loud sound, I can understand the shake (or some rattle). But from stock Bose sounds, it is a bit annoying to hear a humming rattle...
If it's not common, I'll take my car in for a fix. But I just wanted to hear your thoughts first. Thanks in advance.
this car has rattles in various spots. my 2010 has a rattle in the rear deck when i turn up the volumn or when the bass hits hard. it also rattles over rough roads even when the stereo is off. it's normal, but is it acceptable? probably not. you can take it to the dealer if you want them to rip your car apart and try to put in some insulation to stop the rattle.
I got the rear deck rattle too. it all depends on temperature i think. sometime the rattles are there sometime its not. I just try to keep as little of the interior expose to the brutal sun as possible. tints + windshield reflector helps.
