Ok new nightmare lmfao!!! Need help asap calling all sedans
#32
i know i attended sema last year for my window film company.... plus i like to keep up on all the latest window tint trends.... but that still leaves no exscuse not to have at least one man on the phones.... i mean seriously all you get when you call is leave a message. were at sema call ya back on nov 12th!!!!! lmfao hahahhahaha like uhhm well what do i do till then BC? im sure i could call tein and someone would answer the phones and there at sema
#34
cut some of the fender liner in the rear. This will help with negative camber and rubbing.
but if you don't want to do that, then just run more negative camber. Remove your rear suspension and start over again.
the rubber mount should be reused. I'm guessing its not seated properly. Also, for the BC's did you get the stiffer springs for the rear? Cause I know before people complained about the rear sitting lower than the front and thats at highest ride height. BC upgraded the rear springs to be stiffer or customer had the option.
superjoey
31
03-23-2023 12:56 AM
KZK
Canada
08-13-2015 07:17 AM
KZK
Canada
08-12-2015 12:16 AM
