Is Your Outside Temperature Gauge Accurate?
Old 08-20-2010, 10:38 AM
Almatti
Almatti's Avatar
Compared to my old 07 G35X, the outside temp Gauge appears to be way Off? Local weather reports will indicate 78 degress, my guage on the dash will say 82-83 degrees. I complained to dealer a few weeks ago, but they told me some bullsh** that it measures the temperature and humidity , kinda like a heat Index?? That doesn't sound right. I think Infinti changed the location of the sensor in the engine compartment and that may be the reason. It's a petty thing, but hey, I like things to work properly as they are designed to and marketed to.
Old 08-20-2010, 10:43 AM
hispeed-lowdrag
hispeed-lowdrag's Avatar
it MAY run a little high, but it is always pretty accurate. the only reason it might show high is because of the location in the engine bay. but like I said, I've always seen it to be pretty accurate
Old 08-20-2010, 10:50 AM
Almatti
Almatti's Avatar
hispeed - you have an 09. Mine was very accurate in my 07, but it's typically 5 degrees or more too much. When temps in NY were hitting 94-95, readings were while travelling on the highway, 100-102 degrees....in traffic worse.
Old 08-20-2010, 10:52 AM
hispeed-lowdrag
wow...that is WAY off then. If I open up weatherbug on my iPhone while I am sitting in my car my temp gauge is usually w/in 1-2 degrees if not spot on...that is just a normal variation IMO...but 5+ degrees seems like something might be off.
I don't know, maybe they just moved it a bit from 09->10, I'm not sure
Old 08-20-2010, 11:42 AM
DocJohn
G-DOG
DocJohn's Avatar
I've got a '10 and the external temp gauge seems to be quite accurate except when in heavy stop and go summer traffic as was previously posted.
Old 08-20-2010, 11:53 AM
rohardi
rohardi's Avatar
mine is prety close
Old 08-20-2010, 11:37 PM
SCBLKG37
SCBLKG37's Avatar
temp gauge pretty accurate, except when sitting in sun or when traveling on very hot days the radiating heat coming from interstate throws it off a little or sitting in traffic.. All that is expected and with normal operating parameters.
Old 08-21-2010, 06:24 AM
maxfinity
maxfinity's Avatar
My temperature gauge is usually off by a few degrees when i first get in the car on a hot day, but after about 10 minutes of driving its usually dead on give or take 1 or 2 degrees. Nothing Major.
Old 08-21-2010, 10:35 AM
Adam West
Adam West's Avatar
Yes, when the car sits in the hot sun it will read quite a few degrees higher than normal (sometimes 5-10). A 1-2 degree variation seems normal under typical operating condition from what I've seen.
Old 08-21-2010, 11:34 AM
soundmike
soundmike's Avatar
Not sure about your area, but around here, the local weather reports are based off gauges permanently locationed near IAH (Intercontinental Airport - Houston)... 60 or so miles away from me. So, it's hardly an accurate gauge to begin with.
My car is usually spot-on with temp readings compared to local billboard temp readings or even my own outdoor thermometer.
Old 08-21-2010, 12:28 PM
eksigned
eksigned's Avatar
actually, i know what you mean. most cars, you can adjust the temperature. i know on my ex-tl you could, as in our lexus and toyota. there has to be a way to do the same in our G's...hm.........will look into it and report back after i play with the buttons.
Old 08-21-2010, 12:31 PM
TinsleyC
TinsleyC's Avatar
Mine said 117 degrees the other day (Dallas, it was 104 at 5:00 PM) - the car was on a black tar parking lot, facing the sun. Once I drove it about 5 minutes it was down to the correct temp.
Hey, it's a thermometer, it measures the temp around it. When placed in the front near the hot engine it can read high unless you're moving.
Old 08-21-2010, 03:35 PM
amf25
amf25's Avatar
mines always different than the temp per iPhone or radio... several degrees usually
Old 08-21-2010, 04:11 PM
Creepers
Creepers's Avatar
mine is waaaay off. ive noticed it's like 32 degrees outside but it'll say 90!
anyways, i dont need a machine to tell me how hot it is.
Old 08-21-2010, 04:22 PM
zoner
zoner's Avatar
right on! if it's hot it's hot, if it's cold it's cold. why do you need to know exactly? so you can make one of those useless cellphone calls to tell someone how cold or hot it is? people need waaay too much information these days
Quick Reply: Is Your Outside Temperature Gauge Accurate?
