Intelligent Key question
ok, SkyMG37x seems to have a reasonable solution with a RF shielded bag, but where would you get such a thing?
the idea of removing the battery would definitely work but i think that cracking open the fob 3-4 times a week would have long term consequences on its durability and function.
has anyone else found something that effectively shields the RF from the fob? i tried putting it in a candy tin box (and even tried putting the fob in an enameled cast iron dutch oven) and the fob still works.
cheap prices RF Shield Block Pouch BAG For Cell Phone Mobile - 9Mart.com
Senior Citizen
no the person will not be able to start the car without the key inside the fob. The key needs to be inside the fob for the car to be turned on.
-to verify take the key out of the fob and leave it outside the car...get in the car with the fob and see if you can turn it on. (you should not be able to)
Then you remove the mechanical key from the keyfob and give it to the valet who WILL BE ABLE TO START THE CAR WITHOUT THE MECHANICAL KEY INSERTED! But won't be able to open the trunk or glovebox. I gave the key without the mechanical key inserted to the tint shop and other places before who were all able to drive the car just fine.
So, please don't do this. You probably won't be able to get the car locked with the keyfob still inside anyway.
I tried putting the key in the trunk. The trunk simply pop right up when I tried to close it. My G also beeped reminding me that the key is in the trunk. I tried to close the trunk several more times, but each and every time the trunk popped right back up. My G is smarter than I thought.
I ordered one of these RFI shield bags off eBay RF Shield Block Pouch Bag For Mobile Cell Phone Data - eBay (item 250416157014 end time Aug-22-10 22:00:49 PDT) works great. Car doesn't know the keys are near it. :-)
As mentioned above, the small ziplock bag or strong balloon is a great idea.
