Synthetic Oil
Old 07-06-2010 | 03:45 PM
Mino8123's Avatar
Mino8123
Synthetic Oil
Hey everyone I was wondering with the new 3.7 what synthetic oil do you guys put I remember with my 06 I heard that Mobil one I think was bad for our engines. I use to put the Q motor oil or Royal purple. What do you guys put and any info on the oils you guys put pros & cons.
Thank you Mike
Old 07-06-2010 | 03:50 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
read "the definitive oil thread" there is about 100 pages to read about different choices.
welcome to the forum
Old 07-06-2010 | 07:15 PM
eksigned's Avatar
eksigned
royal purple doesn't do much better than mobil 1. if you're on a budget, try pennzoil ultra/platinum. if not, get redline/amsoil. redline's ester based (what i'm running).
Old 07-06-2010 | 08:21 PM
Mino8123's Avatar
Mino8123
What do you think of the Q oil? It was really good for my 06 G
Old 07-06-2010 | 10:39 PM
eksigned's Avatar
eksigned
by Q oil, i presume you mean quaker oil, correct? unfortunately, i haven't had any experience with Q oil, but just out of curiosity, how do you define "good for your 06 coupe?" check out "bobistheoilguy.com"
sorry i can't be of much help
Old 07-07-2010 | 01:08 AM
Mobil1 w/ Mobil1 filters have been good for both my Gs w/ changes every 5k. My oil consumption has always been very minimal (at 5k the oil is still at the high mark on the dipstick) and no valve noise.
Old 07-07-2010 | 01:35 PM
LightsOut's Avatar
LightsOut
Search............
Old 07-07-2010 | 10:14 PM
g37musings's Avatar
g37musings
IF I were going to synthetic, I would look at using German Castrol 0w30 from autozone.
Or Redline...............
Or Motul................
Old 07-07-2010 | 11:15 PM
CougarRed's Avatar
CougarRed
If you change it every 3750, most any certified 5W-30 oil will do fine. Ironically, I'd shy away from Nissan Ester oil though.
If you want to run 5000-7500 miles between changes (or longer), then you'll need to search the forums here, the 370Z forums and the BITOG forums for oils suitable for extended drain intervals. You'll probably want to try some of those oils out on your car, and get a laboratory analysis done.
fuzzed
08-21-2020 10:35 AM
Stevolkz33
05-28-2016 03:36 AM
Junchao Sun
25
10-01-2015 01:41 PM
Chappedj
09-28-2015 04:20 PM
Wreckreation
09-21-2015 07:27 PM
