First service tomorrow - question
Tomorrow is my first service for the car (3 months). I just want to get an oil change done and that's it. Does that affect my warranty or resale value in any way? And do they usually want you to do more than just that?
? how could servicing the car affect the warranty?
and the only thing keeping the car serviced will do to the resale value will preserve it (wouldn't you pay more for a car that had been taken care of versus one that hadn't )
they will do whatever you want them to. just make sure if you take your own oil for them to use that they actually use it
Keep a record of all service done on your vehicle and it will make it worth slightly more. First oil change at 3 months is fine. If you are nearing 5,000 miles or 8,000 km make sure to have the tires rotated as this will make them last longer.
As long as you do the tangible items according to schedule (oil change, filter changes, etc.), you'll be fine. I haven't paid for the intangibles (inspect blinker fluid, etc.) in over 10 years with zero consequences.
As a matter of fact, dealers want to perform inspections to potentially find other service items to sell you. The idea of paying them for an inspection is pretty ridiculous IMO.
Here's a list of the tangibles that you should have done, assuming the 3,750 mile service interval applies to you:
- Change oil and filter every 3,750;
- Rotate tires every 7,500 unless you have staggered wheels;
- Replace in-cabin air filter every 15,000 miles;
- Replace engine air filter every 30,000 miles;
- Replace engine coolant every 60,000 miles; and
- Replace spark plugs every 105,000 miles.
Everything else is on an inspect and/or premium maintenance schedule. Again, I'm not making any of this up and this is not my opinion - this is from the service schedule booklet provided with the car.
By the way, engine air filter changes are amazingly simple on this car. If you have enough mechanical know-how to open the hood, you can change both filters in less than 5 minutes if you work slowly. Cabin air filters are a bit of a PIA, but there are great how-to posts on this forum for this item as well. This is an inexpensive car to own and maintain if you tell the dealer specific items you want serviced. Never tell them you want the 15k/30k/whatever service, or they will send their kids to college on your generosity.
noted.. thank you. First oil change was done quickly.. cost me $59 CDN because they had to add a small amount of oil to the one i brought. I used Pennzoil Platinum.
I don't know if it's just my mind playing tricks but the car felt a lot smoother after the change.
so after 3 months, what was the mileage on the car?
ive never really felt comfortable following the 3000mi/3mo interval - i always drive less than that...90% of my driving is done on the weekends so it takes me longer than 3 months to get to 3000 miles.
my G will be @ 3 months at the end of june, and my car only has 700 miles, so im not even sure when to get that first change done
It has 3k KM on it which is where the first oil change should be done according to Infiniti Canada. Coincidentally i've had the car for 3 months.
I talked to their rep about this and she said to use the mileage as to when to change the oil and not the time period.
For future reference, the manual says the car takes about 5 and 1/8 quarts with the filter installed (i might be remembering the exact fraction wrong but it's slightly over 5). So I'd bring 6 and ask them to give you back the remainder, and you can bring that one back next time (or top-off when needed).
(snipped a bunch for brevity)
i live in nyc, and work in midtown manhattan, so it would be insanity to take the car in to work (and expensive, parking is about $15/day). hence, only the weekend driving
The one thing not on the schedule that I would do at least every 2 years is a brake fluid change. There's no way to tell by looking at it how much water is in the brake fluid, so it's better just to change it every 2-3 years.
That's kind of a bummer if they had to "water down" your P.Plat with some lesser oil. According to the people who market the stuff, adding dino oil to synthetic will not cause any harm but might reduce the benefits you'd get from the synthetic. But that might just be marketing hooey anyway. With a small amount like that I bet it won't make any difference at all, except that they apparently get to overcharge you for it .
