Gas Type...
Gas Type...
quick question. back home alot of gas stations offer 87 91 and 93 octane levels. I am pretty sure i always used 93 back home and i came out west about a month ago and noticed they only have 91 octane in the area i am staying. if i put 93 octane back home and switched to 91 out here is that bad? what is the octane infiniti reccommends in the car and what do you guys put in yours? thanks.
My owner's manual says 91. The experts usually say putting in higher than the recommended won't hurt, but won't make any difference either.
Gas stations around here sometimes have 91 and sometimes have 93. So I use whichever is available. There hasn't been any noticeable difference.
Some run lower grades of fuel to save money. You can do this but if you get engine ping on acceleration, you're running too low of a grade and can damage the engine over time. Just stick with 91 or higher and you'll be fine.
Modern cars contain a knock sensor that detects detonation in the engine (which is harmful) from lower octane fuels and reduce the timing, which results in less power. So you would not ever want to switch to lower than necessary.
Incidentally, most gas stations have 2 tanks, one with higher octane and one with lower octane fuel. They dispense a mixture of the 2 grades to make the various octane levels.
As long as you are using the recommended or greater, there shouldn't be a problem with switching. I've never heard anything about switching between octane ratings being bad for the engine assuming you're not switching to a too-low grade.
91 is fine. So is 92 or 93. Here we have usually 92 octane. But (I think) if I cross the border into the next state it's only 91. If I let's say have a half tank of 92, and decide to gas up over there and top it off with 91 I wouldn't be hurting a thing. Or if my tank was empty, I was over there and I gassed up with 91 instead of the local 92 again I'd be fine. Just don't go under 91.
Oh, and just because it says 10 percent ethanol on the pump (if it does), that doesn't mean you can build a still to distill out the gasoline and drink what's left either.
If you use lower octane, yes you will pay less, but the power generated from it is much less, therefore your gas MPG will drop and you will use more gas. What previous inputs say about the engine is also a fact. It is really not worth it.
Senior Citizen
In my understanding the additives & detergents that make brands differ are more about long-term effects like reducing deposits and cleaning the fuel system, rather than anything that will affect performance from one tank to another.
10 things gas stations won't tell you - MSN Money
misc
29
05-24-2023 03:57 PM
