Alarm indicator
Alarm indicator
Hiya all...I've been trying to figure out some kind of recognition of when the alarm is set and when it isn't. I assume when I lock the car the alarm is set, but shouldn't there be something to tell me so. I see that flashing light, but it's always on and I can't tell if the rate of flashes change or not.
GED
GED
If I remember correctly, you should see the the car with the lock symbol when your first lock your car. I believe this indicates the car is alarmed or something to that effect. Read your manual its in there.
Check owners manual page 2-27...
It also mentions that after you leave and lock the car;
Confirm that the security indicator light
comes on. The security indicator light
stays on for about 30 seconds. The vehicle
security system is now pre-armed.
After about 30 seconds the vehicle security
system automatically shifts into the
armed phase. The security light begins to
flash once every approximately 3 seconds.
If, during this 30-second pre-arm
time period, the door is unlocked, or the
ignition switch is pushed to ACC or ON,
the system will not arm.
CharlieMac646 (11-28-2014)
Thanks guys...I really appreciate.![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
The trouble is/was that the light was flashing even when I wasn't locking the car...I'll pay more attention and report back.
GED
GED
Well, I really paid attention and it just doesn't work the way it's written in the manual...at least in my G.
After I shut the motor the indicator starts flashing; when I lock the car the flashing stops and the indicator stays lit for about 30 second; then it starts flashing again.
Which means, when I or anybody else appoaches the car they see a flashing light; but that doesn't indicate whether or not the car is locked!!!![Dunno](https://www.myg37.com/forums/images/smilies/dunno.gif)
Not the way it should be...
GED
GED
