Bosch Icons Fit 2010 G37X?
Does anyone know if Bosch Icons wil fit the 2010 G37x? I know the Bosch site and Amazon indicate they will not, but I've also seen other posts indicating the do fit.
Yes, they should fit fine. I believe the driver side is 26" and the passenger side is 16". There is a rebate on em right now should be able to pick up a pair for around 20 bucks IIRC.
They don't. Just went through this with my 09. The stock infiniti wipers sit off-center fromt the factory. Go ahead and try...when you put the 16inch passenger side blade on it will hit the A-pillar and the drivers site will rub the roof.
My driver was streaking and I got a nissan refill. No go. Then I told my SA when I had an appointment and they replaced them for free. They did use a new designed blade...or...maybe parts from another infiniti. They are thinner blades but still retain the aero look. They work great, and no rubbing on body parts.
