Garage door opening 2009 g37x
Hi, I am having problems with the "homelink" ..i program the garage door opener to open my garage following the extensive steps in the book because I have modern garage door openers (two door garage with each seperate garage door openers). This programing works for about 2weeks - it will only open the garage door that I programmed it for. But after two weeks, when I press the open garage door button from the g37x ... it opens both of my garage doors. I have to reprogram it and it lasts for two week more ...this is getting furstrating ... any help would be appreciated.
Thanks
Thanks
did you go on homelink.com?
hold the first and third button on the homelink for 60 seconds to reset it and do it over again.
let it relearn the rolling codes and obviously do it on seperate buttons.
homelink.com does help provide you very useful information to specific garage door types and their 1800# customer service is superb.
Thanks
Thanks
The dealer couldn't find any error code at the shop. They had to come to my place to confirm the problem. A new unit was ordered and replaced. Problem solved.<O</O
sorry I have to ask how you're programming the homelink.
Are you programming your garage opener to your remote control, and then the car to the remote, and let the garage learn the programming from your car.
i have a 3 car garage door layout and haven't had any issues. opening 1, 2 and all 3 of them. (using separate buttons) this is with a 3 button remote control if that helps. (a 1 won't work, a 2 might have issues) first batch of 09 released.
3-Step Programing:
1) Clear the memory in your car's Homelink
2) Program the car to the remote control
3) Link the garage "learn" to your car
It is in Section 2-57 of the Owner's Manual.
BOOM_FIST (02-09-2022)
Thanks for all replying .. I have done all the steps as indicated .. based on the replys I called Homelink (did not know they had a service desk) .... I reset everything .. even the 2nd garge door opener while 1st garage door opener was unplugged from the electrical outlet (the one I use) ... now it is time to wait and see what happens ...
Thanks again ...
Thanks again ...
Hi, I called Homelink few weeks goes..and they guided me on how to set up the homelink ... exactly what I was doing ..except they made me re-program the 2nd garage door opener to a new code with the first one unplugged from the electrical outlit.
Guess what ...2 weeks later ..I have the same crappy problem...both garabe doors are opening and closing when I press the first progammed homelink button.... I have not programmed another other homelink buttons to the 2nd garage door .. .going to take it to the dealer ...fed up with this ... it has been 5months that I have been fighting with this issue ....
I think the problem is with homelink version 3 ... Now they are replacing it with Version 4 which has more codes/frequencies that take care of this issue .. I am working on getting mine replace.
I don't have any of your problems but would surely like to find out which version of Homelink I have.
I live in a condo that uses a credit card size card for access. However I cannot program the homelink on my G to open the garage door. Does anybody know how it is done or if it is even possible? Tks
I had an intermittent problem with my homelink. The unit worked from time to time and when it worked the G had to be within 5 feet from the garage door.
I know it's not the door opener since it'll open up without any problems if I use the remote that came with the door opener.
John:
I had to get the tech to my house to try it out. He played around with it for 60 min and concluded it was the Homelink's fault.
<O</O
<O</O
It took a long time to order a new mirror. After they replaced the unit, it has been running fine.<O</O
It was a painful exercise to reset the doors with three cars!
<O</O
<O</O
I live in an condo/apartment complex and we have a garage.I think it has a rolling code as I can not get my car to pair with the opener. Is there an easy way to set my home link with out calling the maintenance guys????
