New 09 G37xS...
Old 01-05-2010, 07:37 PM
Infiniti7
Infiniti7's Avatar
New 09 G37xS...
I just picked up my new g37xS sedan a couple weeks ago. The car is Awesome! I love it. I just have a couple questions about the car that I couldn't figure out. First with the auto seat memory. I have set the car on seat memory 1 to my adjustments. I have noticed when i start the car up it will move to my settings which i want. if i press the number "1" button sometimes the wheel or the seat might move slightly like it was not set to my position after turning the car on. other times when i press it the seat or wheel wont move an inch. I was wondering why that happens sometimes. Has anyone experienced this before? Thanks
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old 01-05-2010, 08:25 PM
Infiniti7
Infiniti7's Avatar
does anyone know about this?
Old 01-05-2010, 10:20 PM
dkmura
dkmura's Avatar
Are you certain that your seat settings were committed to memory? You'll see the '1' button flash twice after you set it. After that, it'll go to those settings when you push the '1' button when the G37xS is set in park.
Old 01-05-2010, 10:34 PM
Infiniti7
Infiniti7's Avatar
ya it is. im wondering when i turn my car on why does the seat or wheel move sometimes when i hit 1 when its in park and other times i hit 1 and nothing will move. it moves about an inch nothing major.
Old 01-06-2010, 12:02 AM
dkmura
dkmura's Avatar
Sounds like you have the memory on a particular setting. My G37xS DS moves to the '1' or '2' seat settings immediately after start up. No fuss, no mess...
Old 01-06-2010, 09:33 AM
zmzmzm
zmzmzm's Avatar
My 6MT car will only move when you press the memory button if the parking brake is on. The Automatic Trans model probably has a similar interlock.
Old 01-06-2010, 09:55 AM
Infiniti7
Infiniti7's Avatar
so when you start the car up and it is in park and you press the number "1" should the seat or wheel move?
Old 01-06-2010, 02:01 PM
dnedawg
dnedawg's Avatar
You maybe putting the car in drive to fast. Once you start the car it takes a moment to move everything. I have foud if you jump to fast and put it in gear the seat and steering wheel never adjust completly.
Another item of note, if you get in your car a little too stiff legged and put to much downward/backward pressure on the seat it will stop its adjustment as well.
Old 01-06-2010, 02:33 PM
Received 4,942 Likes on 4,175 Posts
Do you have the wheel & seat "auto retract" setting engaged? This will move the seat back and the wheel up when you exit the vehicle and stay retracted until you re-enter the car. If you're a big guy the retract settings may not move the wheel & seat too much. Sounds like maybe that's what's occurring. It's a nice feature if you like it, drove me nuts though so I just dis-engaged this option.
Old 01-06-2010, 03:45 PM
da mayor
da mayor's Avatar
did you set your memory to your intelligent key as well? you can do that too.
Old 01-06-2010, 04:02 PM
Infiniti7
Infiniti7's Avatar
the only time i set the memory seat is when i first got the car and had both keys in the car at the same time. i have not reset it to the only key i am using now.
Old 01-07-2010, 10:19 AM
Infiniti7
Infiniti7's Avatar
I just can't figure out why sometimes the seat or wheel moves a tiny bit about less than an inch maybe when i hit 1 and other times i hit 1 it does not move. its like half the time i get into the car and start it up the seat adjust perfect and the other times i need to hit "1" to put it into my setting. I know nothing is wrong with the memory settings either the car is 2 weeks old but i cant figure it out
Old 01-08-2010, 12:40 PM
IgS
IgS's Avatar
Infiniti7 - sorry this is off topic, and is a somewhat of a random question. Since you have 18s due to the sport package, i was wondering if its a staggered set like the non-x models. are your tires all same size?
Thanks and congrats on the purchase!
-IgS
Old 01-08-2010, 11:08 PM
Infiniti7
Infiniti7's Avatar
No i dont really know the size of my tires i think they are all the same size. does anyone understand this memory seat issue? i dont know what the deal is
Old 01-08-2010, 11:23 PM
wingzero1
wingzero1's Avatar
-IgS
I have a G37Xs as well...all the tires are 18in 225/50.
Quick Reply: New 09 G37xS...
