Compatible Bluetooth Cell Phones
To make calls:
1.) You can manually enter your contacts into your car's phone book, and then place calls like that(with any phone). Or,
2.) You can use your iPhone to place calls like you normally would(dial a number or choose a contact). The phone will still be paired to the car, utilizing the BT handsfree system, and will work just like it should. That is the easiest option. There's no way I'm manually entering all my contacts into the car.
You can place outgoing calls. What I'm saying is that you can't download your phone book to the car from your iPhone. The iphone works perfectly fine, there's just no easy way to get your contacts transferred into the car.
To make calls:
To make calls:
OK thanks. I just wasn't sure about item (1) because Apple gets snooty sometimes with other applications and their phone.
This is good news for me, because my wife had to buy a Jabra Handsfree Speaker for her phone, and she cannot make outgoing calls because the Iphone won't let the voice activation of the Jabra connect to the Iphone and search her phone book (Iphone 3g)
I'm using the Nokia N95 8GB and it works perfectly fine. No one ever complained about noise or not being able to hear me so far. It is possible to transfer your contacts one by one to the car as well. Have not played with it enough to see if it would be possible to transfer a batch of contacts to the car.
Also, I suspect that on phones that support BlueTooth Object Exchange, must one manually re-sync when a contact in the phone changes. This is another reason I don't care about the inability of iPhone to download the address book.
I have an iphone 3Gs and it works just fine placing and receiving calls.
I just picked up a 2010 G37 and my Iphone seems to work great with it. My Iphone Contact List shows up on the Infiniti Display, and I can select names manually and call them.
I do think there might be an issue with call waiting. I was on the phone today and someone else called me and my phone shut off. Hopefully it was a glitch...
I had no problems with both my current (iPhone) and previous phones (Sony Ericsson P900i). The only issue I'd bring up is that for some reason my voice is a bit weaker with my iPhone that it was on my P990i. Not significant enough for me to throw away my iPhone (don't you just love that thing? )
I have a BB Tour 9630 and it works flawlessly....had an issue early on where it wouldn't hang up and the person on the other end couldn't hear me, but a hard reset (yanked the battery out while the phone was still on) took care of the problem. The phone connects/disconnects properly everytime I enter/exit the car, and I haven't had a failed in-call connection (yet) since the hard reset.
delfinparis
11-16-2015 02:26 PM
delfinparis
10-08-2015 06:06 PM
butwhatuptho
10-04-2015 07:51 PM
mikysee
09-28-2015 11:18 AM
