how to reset maintenance reminder ?
i have read the fu****g manual and i didn't find somewhere how to turn off the maintenance reminder that is written in red , just behind the wheel
I have bring my car for an oil change before it appears and they didn't cancel it because 500 miles after a reminder apppears
That post is for the reminder on the main LCD screen. OP is asking about the reminder on the red dot matrix window on the instrument cluster.
To reset that,
- Hit the top button on the right side of the instrument cluster until you see the Skip, Alert, Maintenance, etc. screen appears in the red area.
- Use the bottom button on the right side of the instrument cluster to highlight Maintenance and then hit the top button to select.
- Use the bottom button on the right side of the instrument cluster to highlight the desired maintenance item, i.e. Engine Oil, and then hit the top button to select.
- Select Reset.
- Repeat for any other maintenance item.
BTW - Page 2-24 to 2-26 in owners manual. Not clear, but it should help.
I admit it's not very intuitive. You have to switch between the top and bottom buttons in order to move around and select the option. It took me several minutes of frustration to figure it out. Fortunately, Kwik Kar (who changes my oil) resets it for me now.
Can you stop by an Infiniti dealer and get them to show you?
The only option remaining is to contact the dealer. I am not sure I will get an answer without being raked over the coals. I may have to call Infiniti and see what can be done
I agree that it sounds peculiar that one car does not behave like the others, so either I am missing something very basic or the book is not listing it or the system is faulty
Thanks to all for their time
I can't imagine they'll give you a hard time. My Infiniti dealer treats me like a king. Just pull up near the service department and ask someone who doesn't look busy...
4DRZ
Engine, Intake and Exhaust
12
05-18-2017 11:25 AM
delfinparis
10-08-2015 06:06 PM
Junchao Sun
25
10-01-2015 12:41 PM
Victory
09-28-2015 10:49 PM
