Climate control slow to heat up cabin
On cold days I put the temperature to 75 degrees and put the climate control on Auto; the heater takes a very long time to start blowing hot air from the vents, it starts blowing warm air from the foot wells and take another 5+ minutes to start blowing air from the upper vents. Is this normal?
I owned a Nissan Maxima that exhibited this same behavior.
My wife owns a Lexus and the heater start blowing hot air from the vents as soon as I turn the climate control up.
I don't have this issue with cold air, the AC blows cold air instantly when the outside temperature is high.
once when dual zone climate was on..it was set to 68 on passenger and 90 on driver...driver side would't get hot...don't think the system can go full hot and full cold at the same time.
Yes its normal. The Auto will blow air through the lower vents when your heating the car.
And it does take a while. The AUTO function wont blow air until its able to blow warm air.
my commutes are late at night and with the new england chill, it get as low as 5 degrees..my car starts up perfect and the heat is always good once the car gets rolling..heated seats though take a bit and are no where as good as my brothers new 335xi heated seats..oh those are soooo goooood
btw i keep my heat setting at 76 dual auto for both sides..car warms up fine
ok guys here it is from someone who knows cold . The heater will not start to blow warm air until your engine is properly heated up. Your heater is basically a fan blowing accross your heater core. The car will not flow warm fluid through your heater core until the engine has reached a certin temp. Once that happens you get hot air
[quote=madmax2k1;2564787]On cold days I put the temperature to 75 degrees and put the climate control on Auto; the heater takes a very long time to start blowing hot air from the vents, it starts blowing warm air from the foot wells and take another 5+ minutes to start blowing air from the upper vents. Is this normal?
I don't think it's "normal"...we've had our G37x for one month, live in New England, & shocked at how fast the heat comes on.
My hubby just said he never uses "auto" as "auto" has never worked right in our 1999 Audi, nor any other car he's driven. He suggests setting the "auto" heat to 90 or 'Hi", as you want all the heat available when the engine is warming up. Once it's 100% warmed up, turn it down to 75. Of course this isn't as "auto" as you want, but you should get heat quicker this way. (he feels there is still cold air mixing with warm as the engine warms up, so you want all available heat from that engine during warm up to counterbalance the cold to warm....) Hope this makes some sense...
As for why you are getting foot heat 5 mins before upper vents - that's just odd unless the upper vents have more mix of cold air for longer period of time?
Good luck! Let us know if this works, or if you find something is wrong...
[/QUOTE]
I tried the heater again last night by putting the Temp on 90 degrees; it started blowing hot air from the upper vents right away. I guess the amount of hot air it blows is dependent on the outside temperature and the temperature it's set on; the bigger the difference between these 2 temperatures, the more heat it generates.
[/QUOTE]
In a cold day, the engine will take longer to warm up. The heat produced by the engine (waste energy) is used to heat up the car's interior.
In a hot day, the compressor and the refrigerant are the one being used to cool the interior. The engine will be needed to crank the compressor so the results is an immediate cooling. So as soon as you start the engine, the cooling will also start.
