Brake light switch confusion
Yeah so I never messed with before. There’s 2 switches right next to each other. Does it have to be OEM? The third brake light and regular brake lights stay on and car starts without holding brake. I’m just disconnecting battery for now. It seems like just a bad brake switch. Help.
One is your brake switch and the other is for the cruise control. That said your brake switch is likely fine. At the top of each switch there is a rubber pad. It is becoming more common for these to pads to dry rot causing either the brake lights to remain on or the cruise control to not engage. Mine was the cruise control.
Look underneath and check the pads:
In my case it was the cruise but the brake pad disintegrated the moment I tried to remove it.
If this is your issue then:
Dorman p/n: 74015 (thanks to @Jloego for providing that option), or
OEM: 46584-S0100.
Let us know how you make out.
OEM: 46584-S0100.
Tbchalmers
01-14-2024 12:19 PM
