Wind noise from both front windows
at hwy speeds have lots of wind noises from the front of both front windows. can be worse or better depending on the direction of the wibd irself.
You can either try adjusting the window slightly so that it closes "tighter" against the seals or, being car is 14-years-old, replace the seal(s).
Window Adjustment while not specifically for "wind noise" the same premise applies. Also, the GW (Glass & Window) section of the factory manual has detailed instructions to adjust the windows.
Can you narrow down where along the window the noise is more prevalent? ie. corner/ mirror area, top edge, rear pillar, etc.?
socketz67 (09-07-2024)
typeii (09-11-2024)
