Battery Question
Battery Question
Hello I have a 2011 G37x we got a replacement battery from same size is BCI group size: 35 CA at 32 degrees F: 785 CCA at 0 degrees F: 640Freight class: 65. Since then I have had to get it jumped to start but now it's not starting. When pushing the ingnition button it clicks but yes not crank. Could the battery be wrong.?
Can you jump start the car? The battery spec sounds fine. Why was the battery replaced initially? Did you have a shop test the old battery?
They did not test the old battery which was replaced cause I was always having to jump start it. They placed the new battery which is in question and It started fine for bout 2 days and then it was back to having to jump start it however this time I was only able to do that once. So now it will not start with a jump however all the electronics and lights ac all work fine its just clicks and nothing happens.
