Help! Motor swap problems
Okay so me and a buddy pulled the motor out of my 2012 g37 s coupe and swapped it because it started knocking. New timing chain kit,oil pump because the new one was broken at the pick up tube from being dropped,z1 gaskets for everything behind the timing cover,front and rear main seals,water pump and spark plugs. After putting it back in it's throwing codes for both cam shafts sensors and the crank shaft and lost connection with the TCM. We didn't touch the cam shafts because everything was still tight and right we just changed the timing chain and guides because we had it open already. Crankshaft sensor came off my old motor which never had an issue with that code. I've only let it run a couple minutes before I saw the codes and shut it off. It starts immediately and runs beautifully. I know the terminals are loose and wore out so I have to replace those,the battery was dead and hooked up to jumper cables when I started it,could the loose connection be causing the codes or do I need to run it a bit longer and let it read everything more? I sprayed the whole cover down with brake clean so I know the sensors got soaked in that but I didn't figure that could be a problem considering it's soaked in oil usually. Any advice is appreciated.
Low voltage or bad grounds can throw all kinds of codes.
Get a good battery in there, FIX YOUR CONNECTIONS, clear the codes and hope you didn't **** things up with that jump start.
SamL11B
General Tech Questions
08-01-2021 10:09 AM
micafd3s
06-30-2016 04:49 PM
venmichaels
21
06-30-2016 01:00 PM
japinf08
11-13-2015 01:32 PM
