rear defroster not working
Old 12-27-2022 | 12:17 PM
JUANPCM's Avatar
JUANPCM
HI, I have a problem with my rear defroster, I searched here and read a few post but nothing that helped me, the button light turns on, i can hear the click, check fuses but nothing, i bought a tester, checking online i saw people saying the first thing to test is the grid, now i dont see any current coming from the grid, but i do get current at the thing connecting it
If im not wrong the upper one is the antenna, and the bottom one is the defroster. It a bit rusty but it looks like its properly welded to the grid.
Theres current when i touch it and theres current all the way that thick part, it just doesnt work on the lines of the grid.
Olso, i tried pulling this part but it wasnt coming out, how do i get this part out?
Any idea would be appreciate it, thanks!
Old 12-27-2022 | 01:08 PM
ILM-NC G37S's Avatar
ILM-NC G37S
You are getting 12V+ at that wire when the defroster is turned ON, correct?
What about the ground connection at the other end of the grid? There should be a separate connector on the passenger side C-pillar for the ground connection. Is that good?
Also, do the side mirrors defrost when you turn the rear defrost ON?
re: trim removal, from the FSM:
These pieces use both plastic AND metal clips so exercise caution as these clips are prone to breaking.
Old 12-27-2022 | 05:03 PM
JUANPCM's Avatar
JUANPCM
Yes, i do get 12V+ when its on and the mirrors are working too.. at the other side you mean like the passenger side of the window? I haven’t check that area, I thought everything was on the driver side
Old 12-27-2022 | 05:19 PM
ILM-NC G37S
The rear defroster is a grid that has a 12V+ connector on the left/ driver side and a ground connection on the right/ passenger side:
On the driver side you have the white wire at connector B401 which reads 12V+ when the rear defroster is turned ON:
This is the wire you verified has 12V+. For whatever reason, the B401 (+) connector is not shown on the harness layout.
On the passenger side you have the B402 connector which is your ground/ grounding strap which connects to the frame at B403:
This is connection you should check next.
Assuming you have good power and ground connections, then the issue lies with (likely) a break in the filament(s).
Old 12-28-2022 | 11:48 AM
JUANPCM's Avatar
JUANPCM
So i went and checked, the other side, the ground, looks fine too...
I checked the grid several times, havent seen any breaks in the filaments... just spotted something. but not a break..
could that be the problem? how do i check if the ground connection if fine? I also have a multi tester but i dont how to check it with that one... if thats was the problem, wouldn't it light up all the way there before the break?
In the next photo, i get a light all around the red circle.. and then the filaments until the withe line.. beyond that the tester wont light on... in no other places it turns on, the filaments, the other side, nothing... just the driver side and a bit of the filaments
Old 12-28-2022 | 01:41 PM
JUANPCM's Avatar
JUANPCM
Double post, wasnt showing the first time..
Old 12-28-2022 | 02:32 PM
ILM-NC G37S
Set your multimeter to read DC-Voltage. With the rear defroster turned on, place the red probe on the driver-side terminal and the black probe on the passenger-side terminal. Does the meter read 12volts?
I am away from my laptop so I can't see the images clearly. What am I supposed to be seeing in the 2nd pic?
Old 12-28-2022 | 03:47 PM
JUANPCM's Avatar
JUANPCM
What i was trying to show is that i can get the tester to light up away from the thick part of the grid where the connection is, but moving it a bit to check the filaments, after around 1 cm over the filament it stops lighting up
Old 12-28-2022 | 04:19 PM
ILM-NC G37S
I am not sure your test light is going to suffice in this case.
When you have time test for voltage using the meter as I mentioned above.
Once I get back to my MacBook I'll see what else I can find.
From what I see it is a power/ground issue.
Old 12-29-2022 | 10:51 AM
JUANPCM's Avatar
JUANPCM
I do get a reading, its not 12, just 11.87 or something, leaving the red one and testing the grid, a couple of the bottom of the grid read 0.17 and the upper part 1 was around 8 and another 0.17
Edit: the rest around 12
Old 12-30-2022 | 09:26 AM
ILM-NC G37S
If you are receiving power and ground, and the mirrors defog, then my guess is that there has to be a break somewhere in the grid. I doubt it is the condenser as you are getting 12V.
If you have not already, download the DEF (DEFOGGER) section of the factory manual for your car from here. It will explain how to test the grid using your multimeter and some aluminum foil.
From past experience on different cars, it does not take much for these filaments to get damaged or even wear out.
Old 12-30-2022 | 12:11 PM
JUANPCM's Avatar
JUANPCM
I did test with aluminum foil, most of the filaments were giving current, except a couple of them.. sometime back checking about this, found something about a relay that could be the problem but i dont know where it is, it says is below the the driver side.. if the relay is bad, i wouldnt get any current on the grid right?
Old 12-30-2022 | 12:37 PM
ILM-NC G37S
If the relay was bad there would be zero voltage at the grid. That, and the mirrors would not defog either. The relay is mounted behind the left-side fuse block. If it clicks when you press the button, likely it is good. Did you check both fuses?
Sounds like a break in the filament(s). Maybe others will have other ideas/ suggestions...
Old 12-30-2022 | 04:05 PM
JUANPCM's Avatar
JUANPCM
Yeah, thats what I thought, just wanted to make sure… i did check all the fuses, the ones at the lower dirver side and the fuse manual also mentions one around the battery, i did check those too.. everything that mentions defogger…
Old 12-30-2022 | 04:07 PM
JUANPCM's Avatar
JUANPCM
Ill check the filaments again a bit more careful, its just so uncomfortable to work around that area.. not a lot of space
2012G37
01-29-2022 07:56 AM
G37sPhoton
05-14-2020 02:01 PM
apexi957
29
06-27-2012 12:32 PM
Creepers
16
06-28-2010 07:14 AM
Quick Reply: rear defroster not working
