Leak on passenger side
I have an ‘09 G37x coupe with 161k miles. After I park it in my driveway there seems to be a leak under the passenger side. Should I be worried?
Worry is probably too strong a term but you should definitely be concerned.
These cars are notorious for leaks either from the sunroof drain, the windshield cowl, or the firewall wiring harness passthru. Being you have a Coupe, it could also be the door seals or the A-pillar trim allowing water to leak into the cabin.
Check the following:
Because of the sensitive electrics under the passenger-side dash, you need to identify and correct the leak ASAP before your electrics get wet and malfunction. It has happened before to many drivers...
- cabin air filter, if it is wet, then the cowl seal has failed;
- the rubber door seals- you can tell if water is leaking in;
- underneath the carpet (to mop up and dry out the standing water); and
- the BCM- sits on right side of passenger footwell- any signs of water/wet carpet/ insulation indicate sunroof drain failure.
Infin88
12
11-01-2020 11:13 AM
Breitling65
06-10-2010 10:52 AM
