G37 coupe mud guards
Hey guys
I've been searching my damnest and I can't find a set of front and rear mudguards for my G coupe. Waiting for my buddy at Infiniti Parts to run the part numbers on them (999J2-JU0B3 front, 999J2-JU0B4 rear) but not really getting my hopes up via the PD because apparently they're discontinued?
I've been checking a whole bunch of different sites and it's all showing the same thing. Located in Toronto, Canada by the way.
Like one of my options at this point is to buy some used ones (stock on ebay for rears especially is SCARCE) sand them down and paint but ughhhhhhhhh rather just buy some mint ones, even if they are unpainted.
Also what in the hell are these little side skirt canards near the rear called, very subtle but they add a bit more of a flare-out to the side skirt which I love.
Thanks in advance homies
Most pre-painted body parts are no longer available here in the US. Likely Canada as well. However, many of these parts are still available in Japan. No guarantees, mind you, but worth a look all the same.
This is what I found (new/pre-painted) from jp-carparts.com. It seems that the part numbers are also broken down according to your cars BUILD DATE. ¯\_(ツ)_/¯ You can scroll down to get the correct part number based on paint and build date. I would then shoot them a email and see if the parts are available and/or what alternatives are open to you. Last I remember the guy who handled all of that was named Osamu- but that may have changed. From what I gather these are not available "unpainted." From anyone.
BE WARNED, if they do have it, shipping from Japan will be crazy expensive and, combined with potential import fees for Canada, it will quickly become cost prohibitive. For example, I just had to recently order a new passenger-side A-Pillar trim piece and when all was said and done the shipping cost was almost as much as the trim piece itself (≈$150 +/-). In the end you may have no choice but to find a used set and have them redone.
Back ordered from hell though hahah no ETA likely 6-8 weeks realistically. My costs were surprisingly good too $118 for rears and $45 for fronts.
Too bad they aren't currently available, as I'd like to get a set for my coupe.
Those side pieces are these: https://www.jpusaco.com/collections/...iant=581324265
