2009 g37x rear LSD?
2009 g37x rear LSD?
hey I've heard I can't get a rear limited slip differential because the front gear ratio is different than that of a rear different from a rwd g37 thus the gear ratios won't line up getting an aftermarket lsd, does anyone know of a direct fit, or the gear ratio of the front diff on the g37x? To be clear, im looking to get a rear limited slip that is the same gear ratio as my front differential to avoid any issues, thanks in advance
When introducing this differential into your industrial facility case you will find that expelling the direction on the diff to be about outlandish without harm. Z1 suggests supplanting both side orientation and seals when overhauling the back differential. Decide to include another side orientation and seals as an alternative underneath.
192.168.100.1 192.168.1.1 jpg to pdf
https://www.myg37.com/forums/engine-...-on-awd-g.html
